DIY 4x shackle flip
Discussion in 'The Garage' started by jagermiester, Jan 4, 2006.
  1. jagermiester
    jagermiester 1/2 ton status
    Jan 3, 2006
    100
    NV
    Is anyone running this flip and if so do you have pics. I would like to see some more pics of this mounted on a truck.
  2. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    arent there pics posted in the vendor forum where kert sells the things?
    j
  3. jagermiester
    Jan 3, 2006
    100
    NV
    Thanks I would still like a shot from straight behind it if anyone has it
  4. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    It's not 100% straight behind but it's pretty damn close.
  5. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    the new ones have DIY4X cut into the center part where the holes are. but, im sure that kert can cut anything you want in there.
  6. Brocky
    Brocky 1/2 ton status
    May 22, 2005
    1,170
    St.John's Newfoundland, Canada
    I dont want to say one isn't as good as the other cause they both look good and well I dont have either and want to buy them this week, but what are the differences in ORD and Diy4x flips besides the design, any pros-cons.
  7. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    DIY4x, you can make you own shackels, and ajust them to leanght, no holes to drill, backing plates.
    and hell with the new DIY4x cut out that perma sticker gotta add 10HP to your ride:haha:
  8. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    The shackles aren't limited to the stock-style w/ the ORD flip.
  9. chrisb420
    chrisb420 1/2 ton status
    Aug 6, 2004
    652
    Binghamton, NY
    i just got a bunch of parts from kert and they are going on this weekend. i can tell you from what i have seen he makes very good parts and those shackle flips look like they are unbreakable.
  10. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
  11. Brocky
    May 22, 2005
    1,170
    Alright I see I like the idea of the 6 inch shackles. I want 6 inches of lift so this says it will give me roughly 5 inches. So a zero rate and it is done right? Does Diy4x make zero rates? And final question I think... With this set up and 6 inch TC springs in the front with no sway bar, what size shocks should I go with? I was gonna order springs and shocks from ORD so any idea.
  12. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    Im sure he can... the dude can fab. Zero rates ain't gonna even be a challenge.
    Pick a model of shock that fits your needs and then buy the longest one they make and custom mount them.
    j
  13. Brocky
    May 22, 2005
    1,170
    Good point on the shocks. Thanks, I just ordered the shackle flip on his site a few minutes ago.
  14. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Zero rates are simple enough but I don't have any 1" material on hand currently. I may have to look into getting some, and thanks for all the comps guys!
  15. jagermiester
    Jan 3, 2006
    100
    NV
    Thank you all for the replies. I should be picking up either some ord shackle flips or diy sf soon.
  16. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    Here is what I did with my shocks and diy flip. The brackets I used for the shocks are also from DIY. The upper mount is the same Ford bracket commonly used on the front of K5's to mount up 15"ers.
