DIY alignment questions
Discussion in 'The Garage' started by bad_bo_ti, Apr 4, 2005.
  1. bad_bo_ti
    bad_bo_ti 1/2 ton status
    1,027
    OhiO
    i am finally getting around to getting the steering finished on the blazer (after 2 plus years) i got all the cross over steering stuff resting in place (not tightened) i have no tires or rims on the front, i am wondering what is the best way to get this as close as possible. i have read about taking measurements but they are only when the tires are on. thanks chris
  2. bad_bo_ti
    1,027
    OhiO
  3. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    i did an "alignment" on my old boss dragg car once this works ok.
    put a 8" concreat block behind and 8 feet in front of each roter,(or something to rest it on)
    and lay a really strate piece of wood, we used tubeing becuase we were a welding shop and had lots.
    so you lay it on the block and rest it against the roter(or rim) two little clamps will help great too.
    the use a tape and compare your numbers from at the roter to 6/8 feet away and adjust you stearing to make it as strate as you can.
  4. Ryan B.
    Jul 18, 2001
    5,693
    CA
    For the steering wheel i make sure the draglink is adjusted so it has the same amount of turning both ways. (to the knuckle stops), drive in a straight line and recenter the steering wheel.
    For the toe in, i'll jack up the front tire one side at a time. get a nail sticking out of a 2x4 and set it in front of the middle of your tire, then spin the tire so it scribes a line all the way around your tire.. do this to both tires.
    then i measure the distance between the lines on the front vs. the back of the tire and that will tell yout how much toe in you have.. i also make sure to measure up off the ground a certain number of inches and keep that point consistent when measuring between the tires. :thumb:
