DIY glow harness and manual controller Q's
Discussion in '1982-Present GM Diesel' started by tRustyK5, Nov 30, 2002.
  1. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    DIY glow harness and manual controller Q\'s
    I have an 85 6.2 with the 4 pin controller and no harness for the glow plugs themselves. I may be able to rob the glow harness off our parts rig but it's an 82 or 83 and has a different controller. Anyone care to walk me through wiring up a manual glow controller?
    /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/ears.gif
    Rene
  2. calcide
    calcide 1/2 ton status
    Dec 21, 2001
    283
    Re: DIY glow harness and manual controller Q\'s
    This has been covered a gazillion times, so a search will get you some good results. Here's the gist of a manual setup:
    Make sure your glow plugs are AC Delco 60G units
    If you can't get a factory harness, then wire your glow plugs in parallel. Make sure to use connectors that won't vibrate off or you'll be sad.
    Use a ford starter solenoid and a manual switch to actuate them. Wire the solenoid directly to the battery.
    I did this about a year ago and it GREATLY improved my cold starting. The truck will fire up nicely in the morning even when overnight temps were in the single digits F and it wasn't plugged in.
  3. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    Why not use a 12 volt Relay? Im assuming the ford selenoid is just a remote relay. Is it cheaper?
  4. calcide
    Dec 21, 2001
    283
    A ford starter solenoid is a 12V relay, of sorts. It is actually a power contactor, a relay designed to handle large currents for a short duration. You will have problems trying to find a continuous duty relay that will handle the 160 amps for the glow plug system. You can bet that it will cost a ton if you do manage to find one.
    The best part about the ford solenoid is that it is about $5.00. I haven't seen real specs on the ford solenoid, but I figure that it could handle around 600 amps without any problems. Just don't try to run it for more than a few minutes continuously or the coil inside it might burn up. This isn't really a problem, since the glow plugs only need to run for about 15 seconds. I wait ten seconds, start the engine, then run them for another few seconds once the truck starts.
  5. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    Thanks /forums/images/graemlins/thumb.gif
