Diy Sye?
Discussion in 'The Garage' started by dleroy43, Dec 23, 2005.
  1. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    I have read from an unreliable webpage, about drilling and taping the stock mainshaft from a NP241. Then you can fix the yoke to the t-case and run a rev slip yoke drive shaft. I have a long driveshaft already so I dont want to make it longer with a shorter SYE kit. Has anyone tried this or have input? Thanks.
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    Guess that might work but why run the reverse slip yoke? Why not do the drilling and tapping and then wait to pin the slip yoke when you actually break the rear driveline? I am somewhat sceptical about drilling a hardened shaft without causing some strength issues
  3. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,853
    280
    Truckee, CA
    I have no input, but decided that you KNOW you are addicted to CK5 when you see the subject "Diy Sye?" and know exactly what someone is talking about.......
  4. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    Or cuz you see SYE like 40 times a week.
  5. bear76
    bear76 1/2 ton status
    Oct 16, 2005
    1,065
    here
    I know it's not a K5 site, try www.naxja.org. There is tons of info about this (I USED to own an xj until I came to my senses).
  6. dleroy43
    Jul 22, 2002
    1,517
    Martinsburg WV
    Thanks Ill check out that site. I was mostly wondering about the strenth issues of a bolt into the shaft, and if anyone has done it?
  7. dleroy43
    Jul 22, 2002
    1,517
    Martinsburg WV
  8. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Here it goes, Driveshaft Superstore sells a kit for doing just thing. So yes it is doable. However I think it is stupid.
    Advantages of an SYE:
    -shorter drivline(longer driveshaft)
    -more bearing support of output shaft(=stronger)
    -more travel available in a slip shaft vs a slip yoke
    When you drill and tap the output shaft you eliminate 2 of those advantages. There is no bearing to support the shaft(Just the output seal), and your driveline is just as long. Save your money and get a real SYE kit. Or if you have a 208, a 241.
    And yess, removing material from the output will certainly weaken it. A lot? not likely, you'll probably still break a case or chain before you bust the output shaft.
  9. mrhoes
    mrhoes 1/2 ton status
    Jul 20, 2002
    123
    Austin, Texas
    just save up your money for a 241 SYE kit
  10. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
