Diy4x B52
Discussion in 'The Garage' started by noahrob, Mar 14, 2006.
  1. noahrob
    noahrob 1/2 ton status Author
    Nov 26, 2005
    1,878
    Santa Barbara
    Ok,
    I already know I run the risk of getting hammered about using "search", but in addition to that, i am going to ask a dumb question (adn I did use search). I am looking at the picture on the DIY4X website and trying to figure out how the heck that bracket works. My assumption is that it replaces the front "L" hanger for the spring eye as well as the body bushing mount bracket...actually it pretty much replaces everything riveted to the frame in that area. Is that correct? What are those little pieces for that come with the kit? And now what I really want to know, does anybody have a picture of this thing mounted?
  2. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Not a problem for asking the question. I had the same questions when I called Kert at DIY4X4. So I ordered a set and plan on a complete writeup posted on this site, which should answer your questions.
    But, to get to the brass tacks - yes, it replaces the whole spring hanger/radiator support mount assembly. It has adjustment holes, both in the spring hanger bracket - 4 total, and the complete assembly can be mounted in either of two locations pre-drilled on the bracket.
    Again, look for pictures and complete information real soon. I am about to jump into the swap and will get the info posted up soon.
    The pieces shown, capture the nuts inside the frame, making the installation easier for one person as well as keep the bolts from pulling through the frame.
  3. noahrob
    Nov 26, 2005
    1,878
    Santa Barbara
    Thank you very much for the feedback. So the little tabs etc...just go on the inside of the frame to space out the stress so the whole thing doesn't rip through the frame bolt holes?
  4. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i was thinkin bout these as well for a 52 swap over the summer. cant wait for the writeup!
  5. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    Also, the lock nuts are welded to the little tabs.
  6. willymonster
    willymonster 1/2 ton status
    Feb 18, 2006
    183
    PARADISE,CA
    b52s
    i orderd a custom shackle flip from him and they are siiiick they are very stout i also talked with him about doing some 56 inch brackets he said he was kinda workin on it . i havent talked to him for about a month or so anybody heard anymore ?:eek1:
