diy4x bead locks
Discussion in 'The Garage' started by TC4x4, Dec 5, 2006.
  1. TC4x4
    TC4x4 1/2 ton status
    Sep 12, 2006
    831
    Michigan
    I don't see how if you weld them to the out side of the wheel and the holes for the bolt are on the inside of the circle of the rim how they bolt to the rubber of the tire because the tire is on the out sideof the wheel thnaks i am so confused
  2. desertrat67
    desertrat67 Hawk Driver
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    The tire is sandwiched between the welded on ring and bolt on ring thus prohibiting air leakage.
  3. TC4x4
    Sep 12, 2006
    831
    Michigan
    so you weld on a ring and then there is a separate ring that blots on the outside of that?
  4. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
