DIY4X Installed Product pics
Discussion in 'The Garage' started by cegusman, Feb 9, 2006.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Shackle Flip w/ 6" Shackle and 56" Springs
    14 Bolt Razor Back Diff Cover
    Dana Razor Back Diff Cover
    Top notch products.
    Thanks Kert.
  2. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    looks good, why's it on a roll back?
    never mind, just saw your other post:doah:
  3. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    :drool:
    His beadlocks are fantastic too!
  4. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Yeah, I see them on my truck in the future.
  5. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    I can't wait to mount my tires. I'm gonna clearcoat the rings so they retain the raw steel look. Until I get home though they're just taking up space in my DD.
    Diff covers look great. I should have asked him to see one when I was at the shop the other day. Did you end up scrapping your original cage? Too short for you?
  6. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Cage is sitting in my storage for now. Had a short friend interested in it, but haven't talked to him in weeks. And yes it was to short for me. The new cage will be tied bumper to bumper trought the firewall and several frame mounts. Going to cost a good bit of $$ Droped a $1000 down deposit today:doah::eek1:
  7. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    Looks good! Gotta love the color! I want to paint an entire truck that color!!
    Shackle angle looks perfect!
  8. K30Blazer
    K30Blazer 1/2 ton status Premium Member
    Mar 26, 2003
    810
    204
    Santa Barbara, CA
    learn me on them there shackle flips. I know they add some lift and articluation (right?) but I have heard that they can affect road manners quite dramatically.
    I know most aren't concerned about road manners but although my truck isn't my DD it is still driven on the street to get to trails etc.
    Can sumon edumacate me?
  9. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Nice looks just like mine:D . I gotta get a shim for mine as I dont have a CV shaft. I see you have a flange on your t-case so you wont have that problem:bow: . Kert makes some good products:D .
    Ira
  10. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Looking sweet, I can't wait to get mine :thumb:
  11. K5Chris
    K5Chris 1/2 ton status
    Mar 11, 2002
    805
    New Orleans, LA
    looks great. i got my diy4x flip and 56's sitting in the garage. they go on as soon as i get my spring bushings from ord.
    one question, how much lift do you have in the front? you have a 1" zero rate on the rear? does it sit level?
    ive got 6" up front, and im using a 1.5" zero rate for out back under the 56's. im hoping im not gonna be too low in the ass end.
  12. sandawgk5
    Oct 28, 2003
    6,881
    I have a 4" spring in front and I sag a little in the rear. Not much but it is noticeable. Check the before and after thread there are pics in there or my gallery. I have to shim my pinion down so I am just gonna get tapered zero rates to do both at the same time:D. Just gotta find a few angles so I know which ones to get.
    Ira
  13. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    In route!
  14. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    I will be in about a week. Is the 6" flip and switch 6" of lift?
    thanks Shawn
  15. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Up front I have 4" BDS springs, a 4 degree tapered zerorate "gives about 3/4" lift and moved the axle 1.5" forward", and the ord heavy duty fronts shackles.
    The rear is the DIY4X shackle flip w/ 6" shackles, Stock 56" springs flipped backwards, ORD zerorate "Moved axle 1" forward" Axle sits 3" back from stock. Could not move the axle the full 4" back due to Diff cover to gas tank clearence.
    With empty gas tank and nothing in the bed the rear sits a little taller, but should sit level once I get more weight back there.
  16. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    4-5".
  17. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    Looks good!
