DIY4X vs. ORD
Discussion in 'The Garage' started by seattle73k5, Jun 17, 2005.
  1. seattle73k5
    seattle73k5 1/2 ton status
    May 6, 2005
    210
    San diego/Camp Pendleton
    I am looking for to purchase the shackle flip but want to know who has what and what the pro's and con's are to both of them.
    I like the design of the ORD flip, but wish it had alternate hangers other than the stock.
    I really like that DIY4X has hangers that you can change lengths on if you wish.....
    How much lift do both of these kit's get around 4" with stock springs I am reading...so with the DIY4X 6" hangers will that really give you 6" of lift?
    As far as installation of either of these kits, which one has been found to be the easiest to install?
    Thanks for the help and pics of your set ups would be great.
  2. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    I personally chose the DIY kit because of the flat-style shackles. I like the idea of the flexibility of shackles that can be easilly fabbed out of scrap steel, and the added droop I'll get with 6" vs the stock 4" shackles. Plus, it's something totally different that you don't see every day.
    Bear in mind, a 2" gain on 1 end of the spring will only net about 1" of overall lift. I would guess by the measurements I have so far, you could expect to net about ~5"-5.5" out of the DIY kit with 6" shackles. I'll know this weekend when I get the 4" lifts out of there and get my stock 56's put into the shackle flip kit.
    Install was a snap. We just popped the rivets w/ an air hammr and everything lined up. I would think the DIY would be slightly easier because you don't have to worry about salvaging the stock shackle - just toss it aside and put in the new shackles, but other than that, they should be identical.
  3. seattle73k5
    May 6, 2005
    210
  4. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I used the ORD kit. Very easy to install. Well made and the folks at ORD were great. I also used their zero rates. Great stuff.
  5. suthrnchvyguy89
    suthrnchvyguy89 Registered Member
    Oct 10, 2004
    51
    charleston, sc
    do yall have a link to the DIY website? ive never heard of them
  6. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    DIY4X
    Curt is a great guy to deal with :waytogo:
  7. seattle73k5
    May 6, 2005
    210
    Well I did it I just dropped my cash on an order of DIY4X shackle flip with the 6" shackles....can't wait to put them on the rig :D :D :D
  8. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
  9. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Just a little FWIW, When using a homemade shackle flip, the ORD flip, or any others that use stock style shackels you can use lowering shackels for more lift. Just make sure you plate in the open side if you use the cheep ones.
  10. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    :thinking:
  11. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,620
    610
    Hooper, Utah 84315
    A shackel lowering kit uses longer shackels to lower the truck if you flip the shackels it will raise the truck so if you use longer shackels it will raise it higher.
  12. k5-newbie
    k5-newbie 1/2 ton status
    Jun 19, 2004
    399
    Huntsville, Texas
    I have the ORD flip and love it!!! great stuff!!!
  13. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I think you will be very happy with Kert's shackle flip. I don't own one, but I sure like the design. And the backing plates are a nice touch, heavy duty stuff is cool. :thumb:
    :xmas:
  14. seattle73k5
    May 6, 2005
    210
    That's what put me over the top and dropped the cash on DIY4X's kit was the backing plates and the different choices of shackles.....just seemed to have more to it as far as planning...nothing bad against ORD's design it looks killer but to me seems limited to it's design.
  15. suthrnchvyguy89
    Oct 10, 2004
    51
    charleston, sc
    it looks like you would have to completely take out the gas tank to do the DIY4X one, would you have to do that for the ORD design too?
  16. bigcountryk5
    bigcountryk5 1/2 ton status
    Mar 13, 2004
    931
    G-vegas(Greenville) South Carolina
    you could POSSIBLY get away with not dropping the tank but it would make the install for both a ton easier and i think both kert and stephen would recomend dropping it. :grin:
  17. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    I concur on the ORD stuff...evrything i get from them is GQ
    Shackle flip, 205 twin stick and TH350/NP205 drive sleeve.
    PS.... the ORD shackle flip will give 4" of lift,
    then u can fine tune the lift with shackles.
  18. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    I would personally use skys shackle flip they have 2 different shackle holes for better shackle angle and looks a lot more beef than ORD
  19. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    have you seen an ord shackle flip bracket? i dont think it could get beefier. I have an ord kit and the fit finsh and qaulity ar esecond to none. that and the guys are great to work with
  20. Mad-Dog
    Mar 20, 2005
    548
    Ocklawaha,Fl
    ORD's shackle flip is already overkill...anything more would be wretched excess
