diys bead locks..will it work on my rims?
Discussion in 'The Garage' started by supersize75k5, Jun 3, 2006.
  1. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    I have the rock crawler 2.5 inch back spaced rims, I have heard alot of people say that the rims wont work because once the bead lock ring is welded on the tire must be installed from the other side of the rim, and the lip is too big
    I have also heard it will work,
    so my question is does the weld on bead locks, or any other for that matter have any issues with certain back spaced rims,
    I went with these to minimise my grinding on the calipers,
    any ideas?:confused:
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I am pretty sure it is just harder to get the first bead on due to the drop well being the other way around. Isnt it true with shallow back spacing they essentially turn the rim around before they weld the center in? With enough lube and enough ass anything will fit:D .
    Ira
  3. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    Those are the wheels I'm looking at getting to use with the DIY beadlocks. I'd never heard of this problem. I know when I bought my boggers they were mounted on a pair of 15x10 steelies with weld on locks and they didn't exactly come off easy. But with a little muscle and a Samurai they popped off.
  4. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    I think on the DIY4x the inner ring is welded inside the lip. So it doesnt make it any wider, its just inside the rims lip.
  5. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Yep. The inner ring is welded inside the outer lip. Got my beadlock rims sitting on the couch now.
  6. evo
    evo Registered Member
    Dec 11, 2002
    30
    oregon
    some people say you can't use that backspace of wheel because it has a reversed drop center. i have the same set up, 2.5 backspaced wheel with diy beadlocks. and i havn't had any issues. yeah they were a little harder to put on but not that bad. i've heard the real problem is getting the tire off the wheel.
  7. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    (In my best Jeff Foxworthy voice) YOU MIGHT BE A REDNECK IF.......... :haha:
  8. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    hey thank you for the replys guys!
  9. UseYourBlinker
    Jun 7, 2000
    11,117
    I was letting the second coat of paint dry. I also built a fire for them,well the girlfriend was sitting on the floor :haha:
