dizzy questions for a 454
Discussion in 'The Garage' started by dodgedude99, Aug 24, 2005.
  1. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    i have a HEI dizzy for my 454 HO crate motor. the probaly is that it wont sit flush with the intake manifold, it would have to go down another 1/4" or so.
    do GM dizzys come in different lengths?
  2. rumbly truck
    rumbly truck 1/2 ton status
    Jul 4, 2005
    132
    utah
    Is the hei out of a tall deck truck block? MSD has dist with slip collars to adjust the height due to differant deck heights. Are you sure the oil pump drive is fully seated?
  3. dodgedude99
    Jul 12, 2003
    784
    burbia of illinois
    no the dizzy is an aftermarket hei version, i only paid $140 for thru Summit.
    im pretty sure the oil pump drive is set since i prelubed the motor with my drill.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    But did you then line up the oil pump drive to mate properly with the drive pin in the bottom of the distrbutor shaft? That pin has to drop into the slot in the drive shaft before the distributor will seat down all the way.
  5. dodgedude99
    Jul 12, 2003
    784
    burbia of illinois
    i couldnt turn the rotor after i put it in, does that count?
  6. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Nope. That just means that you have gear interference with the cam. You have to look down the hole with a flashlight and see where the "slot" is. Then figure out how the pin is going to be oriented when the distributor is properly inserted. Now rotate the slot so that it will be in the right place when the distrbutor drops in.
    It might take a couple of tries, since the gears force the distributor to rotate slightly as the distributor drops into place.
  7. dodgedude99
    Jul 12, 2003
    784
    burbia of illinois
    Harry after you posted that i had to go out in the garage and check.
    im a dumbass. :p:
    a little twist with a screwdriver, and the dizzy slid all the way in.
  8. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Just think of it as a learning experience. :wink1: Most of us got to figure out ourselves at some point... :doah:
  9. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    BTW, are we gonna get some shots of you and that 454 smokin' the tires? :rolleyes:
  10. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    this is exactly how you learn how to work on stuff, the only way to, experience
    congratulations :D
    you have now learned yet another bit of info
    you will leanr alot more
    trust me..
    its crazy
    you have no idea
    yet :P
    good luck
  11. dodgedude99
    Jul 12, 2003
    784
    burbia of illinois
    once its done and i have broken in the gears.
    it should pull pretty decent with the 454, 465, and 4.88 gears.
