Dizzy?
Discussion in 'The Garage' started by bobalob, Oct 6, 2005.
  1. bobalob
    bobalob 1/2 ton status
    Jul 20, 2005
    157
    Everson, Washington
    okay i want to advance timing and need to move it a tooth to do so. no trouble there but how do i get it to drop all the way and engage oil pump now that they are not lined up. :confused:
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you can use a long screw drive to move the oilpump to get it to line up
  3. bobalob
    Jul 20, 2005
    157
    Everson, Washington
    darn thats so obvious its brilliant :o
  4. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    I usually just set the distributor in until the splines fully engage, then (with the coil wire pulled to prevent starting) just bump the starter until it drops the rest of the way.
  5. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    goin through the same thing right as we speak..
  6. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    and is EXACTLY the same thing i said to do to, very easy, and fast
  7. bobalob
    Jul 20, 2005
    157
    Everson, Washington
    even better! :D
