Dmax/alli in an obs truck
Discussion in 'The Garage' started by muddybuddy, Nov 3, 2006.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
  2. 85-m1028
    85-m1028 1/2 ton status
    Apr 26, 2005
    485
    costa mesa california
    (Homer Simpson drooling) aaaahhhhhllllaaaacacccallllDuramaxaaahhhllaacaa!! the only thing that sucks is swapping the gage cluster and acc.??:doah:
  3. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,927
    343
    Fort McMurray, Alberta
    I'm still trying to figure out why you have to put the dmax gauge cluster in, while you don't have to with a 6.0L, or other gas engine...
    I'd absolutely love to do a dmax swap on my truck, and there are lots in wrecking yards in the 8 grand range for a full parts truck that can be parted out to recover much of that cost, seeing as I wouldn't need the diffs, tranmission, t-case, or any of the interior etc, but if I have to swap a 95+ dash cluster into my truck to get the dmax cluster in thats hardly worth it...
  4. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    for a dmax/alli combo, id swap clusters :)
  5. Russell
    Jun 23, 2000
    7,927
    343
    Lots of guys have swapped a 95 dash cluster into one of our older trucks. It looks very good, and apparantly isn't too blindingly hard either. Most of the work comes with getting the ducting to work, and in the wiring.
    Only issue I've heard is that the new dash is a lot taller than our older ones, so they either reduce leg room and put the steering column on your lap, or they sit up too high and reduce visibility. That said, the guys who have done it say it isn't that big of a deal.
    It'd be pretty easy to swap the dmax cluster into a 95+ dash too, they are fairly similar...
    I personally want to do a dmax / NV4500 swap into my truck, but if the dmax winds up being this significant of a modification, I'd rather just do the 6.0L...
  6. uao85
    uao85 1/2 ton status
    Jan 2, 2004
    1,867
    Edge of insanity
    its because with the gas engine computers, the sensors and signals from those sensors are similar to all gm gauges(oil pressure, coolant temp, vss in some applications), and can be wired straight up. Or, the computer is compatable where you can change the signal to a different pulse(tach only). But with the diesels, they work on a completely different signal, voltage, hertz whatever it is, cant think of it right now. Bottom line, you cant just whip out a autometer catalog and get the right gauges because they dont make any that are compatable to my knowledge. But......it might be possible to take apart the late model gm cluster and mod them to fit into an older style cluster like we have in the older gm trucks.......just a thought.
    Regards,
    Remington
  7. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    I would love you to put a duramax/allison 6 speed in my avalanche. Just not very cost effective unless you find a wreched donor real cheap.
