Do 14 bolt FF or SF come in 6 lug patterns?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Stomp, Mar 11, 2002.
  1. Stomp
    Stomp 1/2 ton status
    Feb 23, 2002
    168
    Hill Air Force Base Utah
    I think they only come in 8 lug??
  2. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    SF come in 6 lug patterns, and you can make 14 FF 6 lug if you want to. There are two guys that I run around with that have 14b with 6 lug one is a ff the other is a sf
  3. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    You can get 14b sf in both 6 and 8 lugs. 14b ff are 8 lug but you can covert them over... Donovan is the man to talk to about a converstion kit because he made some up... /forums/images/icons/smile.gif
  4. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    The 14FF only came from the factory in the 8-lug configuration.
    The 14SF came in 8-lug and 6-lug varieties. I also believe a few 5-lug versions were found here and there (such as on the 454SS pickup). I don't think the 6-lug version was available until the "new" style pickups w/ IFS were introduced in '88, the 6-lug was used in the light duty 2500 (3/4 ton) versions while the heavy duty 3/4 tons used an 8-lug version. A few 1500 (1/2 tons) with some combination of trailier towing packages also had 6-lug 14SF's.
