Do 8 lug rims have to be 16 inch?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RyansRod, Mar 26, 2002.
  1. RyansRod
    RyansRod 1/2 ton status
    Jun 13, 2001
    118
    Bay area CA. USA
    Looking to upgrade rims to fit 3/4 ton or 1 ton 8 lug axles, have standard 6 lug dana 44 and 10 bolt in rear. I want a 10 inch wide rim, but whats the minimum height?
  2. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    you can get 8 lug rims in:
    15", 16", 16.5", and 17" diameters. And I'm sure even more on the custom market.
    If you go with 15's you'll either have to run about a 2.5" backspacing or grind your calipers down to fit the rims. Lotsa options in the 15" tire line though.
  3. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    i am runnin 15" stockton wheel beadlocks on the front of my D60 and they have 3 1/4 back spacing...with very little grinding
  4. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>I run 15x10 with 4 1/8" backspace, its a little more grinding.
  5. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    is there a backspacing that has no grinding? or one with the least...? more backspacing means the tire sticks out from the fender further right?
  6. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Numericly lower backspacing means the tire sticks out further. This also means you loose turning radius and there will be more stress on the wheelbearings and ball joints.
  7. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,075
    486
    Grand Rapids area
    15" Rims are rare in 15", but they are available. They are all steel. Don't even bother looking for alloy 15" 8-lug. All Chevy rears fit 15" wheels no problem (unless you do a rear disc conversion). The front is the issue. The problem is just that the 8-lug pattern is so big that it drives out the size of the rotor. Even though 1/2-ton and 3/4-ton calipers and pads are the same and the swept surface is the same, the 8-lug versions take up more diameter. 1-ton calipers will require even more grinding.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It won't hurt anything. If you don't like your tires sticking out, like I don't...just grind more.
    I converted my 3/4 ton front to 6 lug because the 8 lug stuff was trash...now I'm thinking I'll leave it that way since I'm buying new black rims--I'll just buy two 6 lug 15x10s and two 8 lug ones for the rear...that way I won't have to grind at all!! The 6 lug stuff bolts right on the 3/4 ton front axle.
    Only problem is that if you want to carry a spare, you've got to carry TWO! I don't carry one though, I don't venture far from home so I'd just go home and get one of my spares if needed.
