Do ALL 205's take 80-90w?
Discussion in 'The Garage' started by Skyetone, May 12, 2002.
  1. Skyetone
    Skyetone 1/2 ton status
    Apr 10, 2002
    118
    SLC Utah
    Do ALL 205\'s take 80-90w?
    Man this HAS to be one of them stupid Q's you just have to ask. I at least can justify...I've stumped a few.
    I drained the t-case...It spit oil about 2feet backwards. It looked and felt like old 10-30..then I left the plug out for a while while I was doing my rear disk. Well I got the axle on and the truck back to the ground. The t-350 was getting rebuilt so ALL that was there was the 205. It started dripping on the driveway (shocker i know) but it had a red hue to the oil? WTF? I heard that 208's take ATF? is there a seal I should replace prier to hooking the trans back in? It doesn't seem to have a way to get ATF into the 205 but I don't know [censored] yet...:D Please give me some SOLID STATS....
    I like this board.. I don't get flamed /forums/images/icons/smile.gif
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Re: Do ALL 205\'s take 80-90w?
    203 = 10W 30
    205 = 80W 90
    208 = Dexron Mercon
  3. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    The factory put ATF in some of the NP205s for better on road fuel mileage. Also if the seal between the trans and TC goes out then you'll pump atf from the trans into the TC.
  4. Skyetone
    Apr 10, 2002
    118
    SLC Utah
    why in the hell would chev do the guessing game of fluid in the t-case? I will throw in 90w but it is stupid that one case takes ?10-30? :rolleyes: and then gear oil then ATF. Oh well maybee I should stick with toyota /forums/images/icons/smile.gif it's all 90w except the motor.
  5. donimator
    donimator 1/2 ton status
    Jun 11, 2001
    444
    Tacoma WA
    The seal between the tranny and t-case is bad. I have had the problema few times. The last time I checked my oil in the t-case, I pulled out the filler plug and it started shooting out a large amount of ATF. That pissed me off, because the Tranny shop had done the last install on my tranny and t-case. So I had to pull the t-case and replace the two seals in the adapter.
  6. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    I checked my '77 Chevy truck service manual last night. Chevorlet says to use either 80w or 80w/90 GL5 gear oil in the SM465, NP205, and the front and rear diffs. Clymers' manual says use ATF in a NP205. So there it is right from Chevy in their own service manual use 80w/90 GL5 gear oil. This should end this now.
  7. Skyetone
    Apr 10, 2002
    118
    SLC Utah
    soundsa about like my trans was leaking. It was just a little. Good thing I just had it rebuilt then hu!! Thanx for the info....
