do any of you run atf instead of powersteering fluid?
Discussion in 'The Garage' started by **DONOTDELETE**, Apr 8, 2002.
    any reason why this wouldn't be ok. one less type of fluid to carrie on the trail.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I do. I really don't know why, beside the fact that is what my dad has always done, and what he told me to use so I do. It might have a lower foaming tendency, cool better, and leak slower for being thicker. I don't know this for sure though. Just guesses.
  2. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    they only thing I use is atf powersteering is to much for that little bottle and everybody I know uses it also
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i use it as well /forums/images/icons/smile.gif
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I use ATF
  5. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    i was told not to bcuz it isnt good for the seals or the pump and gee they tell ya to use powersteering fluid for some reason ....
  6. TheLakeRat
    TheLakeRat 1/2 ton status
    Nov 29, 2001
    363
    San Angelo, Republic of Texas
    Power steering fluid is just a light weight hydraulic fluid.
    ATF is just hydraulic fluid with some other additives.
    The problem is these additives have a tendency to dry out the rubber o-rings in all steering boxes. I'm not talking about a small difference either. I would say that of all the boxes i've rebuilt, the ones that have ATF in them are in twice as bad a shape as the ones with PSF. You can run ATF in your steering, hell i used to do the same thing. In fact that's all i used to carry for spare to save room for other parts.
    But I rebuild these boxes all day long so if i have problems it costs me next to nothing to rebuild it.
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I don't recall ever having used PS fluid. Always ATF.
  8. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Like the other guy's I run ATF...It's way cheaper,than power steering! Never had any problems.
  9. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I've used the atf for years in my power steering. When figure cost of a rebuild kit for your steering box, and pump, verses the price of power steering fluid, verses atf, hell, the pump and box will last years with the atf, of atleast all mine have so far, and atf is alot cheaper then power steering fluid. It's your choice, do what you want.
  10. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Everyone in my country uses ATF. You'll have a very hard time searching for PS fluid. My PS pump is 23 years old and so far seals went bad until last year.
  11. tRustyK5
    Jul 23, 2000
    36,184
    1,388
    E-town baby!
    I use PSF in my Jimmy...it's not like I go through 12 quarts a month so the cost never concerned me too much. I figured if there wasn't any difference between ATF and PSF they wouldn't have bothered making PSF...
    Rene
  12. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Power steering fluid and ATF are the exact same thing with the exception that power steering fluid has an extra additive for the longevity of the seals. I have used ATF in all my GM cars for years and have never once had any trouble with it.
  13. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    How much fluid do you guys put in? You got a leaky box or something....might be because of the ATF fluid? I rarely have to add fluid, and the difference is a few dollars to get actual PS fluid vs ATF.
    I would assume the guys who built these things say to use PS and not ATF for a reason. And just because it works with ATF doesn't mean it is right.
  14. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I put some in about once or twice a year.
  15. mudrunner78
    mudrunner78 1/2 ton status
    Sep 7, 2001
    366
    Rocksprings, TX
    all the army uses is ATF. I personally use powersteering fluid, now when I finish my trail truck it will be completely atf, reason being is the hydro assist take alot of fluid so If I rip off a line I can just fill it with atf. Jesse
  16. well, that was an overwellming yes. my old man always told me it could be run as a substitute but i've been running it full time. love the response time on this board! /forums/images/icons/cool.gif
  17. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    i also use it as a matter of fact the pump on the blazer's are the same thing as the hummers and the military manuals call for 10w or atf but not together it has to be one or the other!!
  18. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    I have allways used ATF. The stering box on my truck leaks quite a bit around the seals, I have been putting type-f fluid in it recently and it doesn't leak it out as quickly as dexron fluid, I need to bite the bullet and put another box on it anyway.
  19. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I always use PSF only.
    Come on guys, the little bottle is maybe two bucks. Even when my lines were leaking (fixed that by now) I just used the Coastal brand PSF.
    I know we GM guys are cheap, but spend the extra quarter for PSF.
    -- Mike
