Do Blazers need crossmember mods w/Doubler kit?
Discussion in 'OffRoad Design' started by johnnyK5, Dec 27, 2001.
  1. johnnyK5
    johnnyK5 Registered Member
    Oct 5, 2001
    95
    Washington, PA
    I have TH350/NP203. Also; since the Doubler is same length as my setup now, I need no driveline changes. - correct?
    "Baby it first, floor it second!" -correct.
    "Floor it first, baby it second!" -incorrect.
  2. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    No you need to change some stuff,
    the rear shaft will be the same, and you can use the old yoke, the front shaft will have to be lengthened, and the cross member(s) will need modification. they recommend you run two crossmembers, one under the 205 and one in the stock location, but you need to have a tunnel built into the front crossmember to clear the front shaft, take a look at the Offroad Design site and it'll show you what i'm takling about, except that the pics they have on there are of the gen 1 and the gen 2 is a little different, but basically the same. I know all this b/c i have one sitting in my driveway waiting to climb into its new home. Just need my welder to come in and i'll be crawlin in 4:1.
    Leland aka RaisedK5
    "Of all the things I've lost, I think I miss my mind the most!"
    "Are the voices in my head bothering you?
  3. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    Depends on your lift and if you clocked it or not. Mine is clocked only 1" and I was able to clear over the front crossmember without any mods. You will need a second crossmember for the doubler adapter to attach to though. Your speedo cable will probably be too short also.
    I thought I was wrong once,
    but I was mistaken
  4. johnnyK5
    Oct 5, 2001
    95
    Washington, PA
    So does ORD sell the crossmember with the channel in it?
    " IT AINT DEEP !! " -common phrase from that guy who doesn't drive to the local mudhole.
  5. RaisedK5
    932
    Long Beach, CA
    Not to my knowledge, you just have to find a local welder that will do the custom work to the cross member. Or find a freind that you trust with a welder. It isn't really that hard to do. take a look at that pic on their site, its basically a chunk cut out of the crossmember, a chunk of square tube with one side cut off and a bunch of reinforement gussetting. shouldn't take but a few hours for a competant welder.
    Leland aka RaisedK5
  6. johnnyK5
    Oct 5, 2001
    95
    Washington, PA
    Shuck's! Why can't everything be bolt on?! lol
  7. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    It is all "bolt-on" once you modify it. lol
