Do Chevy from calipers use the 10mm or 7/16" banjo bolt?
Discussion in 'The Garage' started by afroman006, Feb 25, 2004.
  1. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    Do Chevy from calipers use the 10mm or 7/16\" banjo bolt?
    I'm trying to order my disk brake brackets and hoses but I dont know which calipers use which bolt. I'm using the Chevy calipers, not Caddy. So, 10mm or 7/16"?
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Re: Do Chevy from calipers use the 10mm or 7/16\" banjo bolt?
    what year calipers? chevy used both.
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    10 bolt calipers used 10mm
    dana 44 calipers used 7/16
    dana 60 calipers used 10mm
    /forums/images/graemlins/waytogo.gif
  4. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    Acctually, the first two years of the dana 60, 77- mid 78 used A 7/16" banjo, when the 10bolt came in in 78?? they changed to 10mm. I have 7/16 60 calipers in my truck, and they came on my 77 60 front. My father in laws application catalogs, (works for a remanufacturer), lists the different calipers with the only difference being the banjo fitting.
  5. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Tough to tell. I order new calipers from NAPA for my 78 K10. One was 10mm and one was 7/16". It took me two full days of trying to figure out WTF was going on. NAPA had no clue either. It could have been an issue of putting the wrong caliper in the wrong box, but both bolted up fine and are still working fine even with different size banjo bolts. I almost retapped one (but didn't want to take the chance) and NAPA wouldn't let me return it as I had already threaded them and put fluid in them. Oh well, that is my luck /forums/images/graemlins/angryfire.gif
  6. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    If your calipers are original (not rebuilt) they should be 10mm. When they are rebuilt they usually re-tap the holes to 7/16. Check the major diameter of your exsting banjo bolts. The 10mm = .394 diameter and the 7/16 = .437 diameter.
  7. afroman006
    Aug 21, 2002
    2,876
    AW crap. I ordered my hoses and brackets last night with the 10mm bolts. Can I change it to 7/16"? I haven't bought the calipers or rotors yet so I'm going to get rebuilt ones. Thx
  8. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    This is not necessarily true either...my calipers on my 74 and 75 D44's are original and they are both 7/16" /forums/images/graemlins/thinking.gif
  9. bggrnchvy
    bggrnchvy Registered Member
    Jan 21, 2005
    48
    Cupertino, CA
    My ? is what length of banjo bolt? The local parts place has 3 lengths for a 10mm -1.5 banjo bolt.
  10. bggrnchvy
    Jan 21, 2005
    48
    Cupertino, CA
    Anybody know?
  11. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    should just be able to ask for the yr of vehicle of the calipers you are using to get the correct banjo bolts.
