Do dana 44's bolt directly on?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by loudandproud, Sep 7, 2001.
  1. loudandproud
    loudandproud 1/2 ton status
    Jun 27, 2000
    451
    Ham Lake, Minnesota
    Do dana 44\'s bolt directly on?
    I was wondering if dana 44's are a direct bolt on? If not what other things do you need to put them on?
    Thank you
    <font color=blue>'90 Jimmy</font color=blue>
    Web page - http://coloradok5.com/gallery/album08
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Re: Do dana 44\'s bolt directly on?
    The caliper has a differant fitting then a 10 bolt for the brake line so you will need new brake lines. Other then that it is a bolt in.
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  3. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    I used my 10 bolt front calipers on my d44 HD
    I didn't have to bleed the brakes or anything...just bolt on and goooooo!
    Surfing is Life...
  4. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    What rotors do you use, the 44 or 10 bolt rotors? I was just trying to figure out what I was gonna do since I just bought Stainless lines but am putting the 44 in.
    Thanks!
  5. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    On mine, I'm running a 10 bolt with D44 rotors, caliper brackets, and hub assembly's. I'm using the factory 10 bolt calipers though. This was all do to my 8 lug swap. Just put the 44 in and bolt the 10 volt calipers up. They'll work.
    Kyle
    89K5
  6. bigblue
    Dec 6, 2000
    658
    southern california
    I thought i was going to have the same problem...Just use the stainless steel lines you bought with your old 10 bolt calipers. Use the D44 rotors hub etc...
    Surfing is Life...
  7. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    D44 will go right in. I personally swapped all my 10B stuff from the backing plates out on and still used my 10B calipers.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  8. loudandproud
    Jun 27, 2000
    451
    Ham Lake, Minnesota
    Ok thanks guys, now all I have to do is search for a D44 with 4.56 gears.
