do do i tighten rockers properly?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by aaaaggh, Aug 13, 2001.
  1. aaaaggh
    aaaaggh 1/2 ton status
    May 4, 2001
    161
    birmingham alabama cause there no ham like birming
    i just got a 350. the rockers are just bolted on enough to keep them from falling off and getting lost. a few of them are tight and the rest arent. is there some special way that im supposed to tighten them?
    friends romans countrymen, lend me some parts
  2. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    Yes, but it depends on if you are running a hydraulic or solid cam and lifters.
  3. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    They give a descent description of how to do the adjustment of both, depending on which type you have. Click at the bottom on hydrolic or solid/mechanical
    <a target="_blank" href=http://www.cranecams.com/techhelp.htm>http://www.cranecams.com/techhelp.htm</a>
  4. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Ther are prolly several dozen ways to do this but I will tell ya how I do it.
    I start at the #1 cyl and I use the intake opening exhaust closing method.
    Meaning when the intake rocker is opening I adjust the exhaust rocker and roll the engine over until the exhaust is starting to close and adjust the intake.
    To adjust them I run the rocker nut down while spinning the pushrod in my finger until there is a SLIGHT restistence felt and then I give it a 1/4 turn more.
    As I said there is alot of ways to do this and every one has there own way of doing it.
    my truck's not dirty, it's earth tone paint
  5. POWERMAD
    Mar 4, 2001
    3,466
    Oregon
    OOPS I had that bass ackwards. [​IMG] [​IMG]
    It is exhaust opening and intake closing. EOIC
    I was on my way back from Portland and it hit me that I goofed.
    I logged on and expected to see 35 posts telling me so.
    [​IMG] [​IMG]
