Do early 90s TBI engines have Cam Lobe for Fuel Pump?
Discussion in 'The Garage' started by bigoltrux77, Nov 3, 2006.
  1. bigoltrux77
    bigoltrux77 1/2 ton status
    Jun 12, 2002
    318
    Fort Polk, LA
    I had this question in one of the other rooms, and didnt get much insite. Does a late 80s early 90s TBI 350 have a cam lobe to push a mechanical fuel pump push rod? Or is there just a place to mount it, needing a block off plate. If not, will a stuck push rod hurt the engine? The rod is stuck where a rod should be, but the engine can still be turned by hand, doesnt get caught on the rod at all.
  2. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,923
    333
    Fort McMurray, Alberta
    My 89's 305 neither had the hole bored for the pushrod, nor had the lobe for the pushrod either
  3. BadBob
    BadBob 1/2 ton status
    Aug 14, 2005
    158
    Lyndon, KS
    if it's not catching the rod, it's not going to hurt anything.
  4. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    My 87 didn't either. Even if it does hit the pump rod it won't hurt anything. That's what it's designs to do. All that will happen is that it would slide to to the block off plate and sit there.
  5. mostwanted
    mostwanted 1/2 ton status
    Feb 5, 2006
    765
    Kansas City, MO
    I asked this question a few months ago when I tried to switch to mechanical FP. Nope
