Do I have a Gov-locker???
Discussion in 'The Garage' started by TruckNutzDude, Dec 14, 2003.
  1. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    Just got back inside from romping in the snow. I was looking out the window like the cool guys do when wheeling and thought I'd see if I could get away with running in 2WD. Well, to my suprise BOTH rear tires spun and I went nowhere. I just swapped in a set of 1 ton axles from a diesel truck not too long ago, is there any way to tell if I have a gov locker in the rear? Both tires spin in oposite directions when the truck is on stands and only one tire will spin in some situations. I don't have any information on the donor truck so the G80 code means nothing. Thanks for any help... hopefully it's just a tight set of spider gears and both tires are losing traction. /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    my open 12 bolt will spin both in certain situations.. its probably open, and since its snow..there isnt much to keep both from spinning..
  3. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    I really hope it's just an equal lack of traction. I know I can spin both front tires with the Dana 60 in mud... Does anyone know what a gov-lock would look like if I took the rear diff. cover off?
  4. Confedneck
    Nov 1, 2002
    5,236
    i think on a 14bff, the govlock carrier has 3 holes in the carrier? i might be wrong though..
  5. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    Can someone confirm this? If so, I'll be out in the snow with a ratchet pulling the diff. cover off tonight! /forums/images/graemlins/crazy.gif
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    govlok was what was in at least the 12 and 10 bolts since late 70s but after 73 at least, and is in the 14 bolt SF, but i dunno about 14 FF, i think 14 FF didnt get gov but got soemthing else, some kind of lok unit, i need to look in the GM data book and i could find out
  7. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Yep govlock has the 3 big holes around the outside open has 4. Gov-locks in a 14 bolt aren't that bad it's the 10 and 12 bolt's that are notorious for grenading /forums/images/graemlins/thumb.gif
  8. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    yup 3 holes in the carrier for gov lock
  9. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    Yes that is true. I stripped all the insides of my gov-lock. So becareful if you do have a gov-lock.
  10. unick
    Aug 16, 2003
    4,286
    is it true that if you have a gov lock you cant put a detroit in it?
    lmk
    Nick
  11. Confedneck
    Nov 1, 2002
    5,236
    nick, that is correct, you have to find an open carrier to replace the govlock carrier..
  12. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Yup its true, the carriers are different for a Gov-Lock and open. You have to have an open carrier to put in a Detroit /forums/images/graemlins/frown.gif
  13. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Yes with every body else on the 3 hole gov-loc. On a better note, well sort of, tractech (as in lockright and no-slip) makes a no-slip locker for a 14FF gov-loc case. It isn't a bad way to go for many. Depends on how hard you want to wheel though. I have no personal expierence with it.
  14. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    I am hard on my rig /forums/images/graemlins/grin.gif I'll be even harder on it when I get my 39.5" Boggers... I can't (don't want to) check and see if I have a grenade lock right now due to the freezing rain. I'll check after work, hopefully it's not a gov-lock....pleeeeeaase don't be a gov lock /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/rolleyes.gif
  15. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    This is what an open 14b ff carrier looks like with one half removed. You can see where the 4 "holes" thing comes from. A Gov-Loc carrier will have 3 rather than 4.
  16. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    Are those spyders welded to the cross shaft? I have never seen it done that way. If it is how well did it work? (semi-hijack begins here)
  17. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I hate to say it, but do a search. Kidjethro has been pimping those pictures for a long time on here, and from the looks of it, he did a great job.
  18. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Yes, they are welded to the cross shaft, in 8 seperate spots. Rather than go into it in detail, here is a link to a post I replied to with more pictures and an explaination of how I did it.
    14b welding Jethro style.
  19. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    No Grenade-Lock /forums/images/graemlins/thumb.gif I didn't even pull the cover yet. Just roasted one tire in back and one tire in front in 4WD. If I'm not mistaken that is an open carrier /forums/images/graemlins/crazy.gif what a relief.
  20. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Not so fast, if the Gov-Lock is not working it will sometimes act like an open diff.
    To be sure/positive just remove the cover !
    good luck
