Do I have a lift?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 4wood, Sep 17, 2003.
  1. 4wood
    4wood 1/2 ton status
    Jul 27, 2003
    116
    Atlanta, GA
    My '87 K5 was in the shop to have the wheel bearings replaced, and the mechanic inquired as to who had put my lift on. I was under the impression that I was driving stock. I am running 33 BFG MT's and experience a little rubbing when turning on sharp inclines. Does anyone know how I figure out if I have a small body lift or an add-a-leaf or something? Thanks!
    -W IV
  2. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Stock front springs will have a negitive arch to them.
    Positive arch springs are curved like a U. And most likely blocks will be used for the rear axle.
    A body lift will leave gaps at the front and rear bumpers and the pucks are pretty noticeable.
    Alot of folks are running 33's and stock springs.
    Most likely if you are rubbing with 33's you do not have a lift.
  3. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    I agree. You can run 33's on these w/ only minor rubbing.
    Also, in addition to the negative arch in the front springs, it should also only be two leaves. If you have more it may be an add-a-leaf.
  4. 4wood
    Jul 27, 2003
    116
    Atlanta, GA
    I appreciate the help.
    W IV
  5. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    If you have a front HD suspension ( like mine ) it will have 3 leaves stock, and ride stiff as hell!
  6. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    mechanics arent known for being the brightest bunch
  7. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    look where your body mounts to the frame. There should be a rubber puck between the frame mount and the bottom of the body.if you see any kind of spacer between the puck and body or frame it might have a body lift on it.
