Do I have ABS?
Discussion in 'The Garage' started by tch777, Oct 10, 2005.
  1. tch777
    tch777 1/2 ton status
    Jan 15, 2003
    244
    Colorado Springs, CO
    How can I tell if I have ABS in my Suburban in my Signature. I bought it from a Dealer used and they did not say anything about it.
    Tim
  2. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,852
    280
    Truckee, CA
    90 and 91 had 2 wheel anti lock if i remember correctly....im thinking it was RWAL (rear wheel). I dont' remember if it stays engaged in 4wheel drive or not thouhg.
  3. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    485
    Grand Rapids area
    Do you have ABS?
    Yes, everyone has abs. Unless your body fat is relatively low you won't be able to see them, though.
  4. tch777
    Jan 15, 2003
    244
    Okay I was just curious, because there are times when you jam on the brakes they just seem to go soft and then if you slowly apply them they seem to grip harder.
    That and all the other ABS systems I have used, the brake pedal pulses and you can hear a humm from the system.
    I am guessing the ABS for the 90 and 91 is just a controlled pressure bleed that is varied based on the VSS input for the rate of deacceleration?
    Tim
  5. thfonz98
    thfonz98 1/2 ton status
    Feb 19, 2005
    319
    Salinas, ca
    in 4wheel drive, abs is not enabled
