Do I have DW???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Nrose07, Jun 11, 2002.
  1. Nrose07
    Nrose07 1/2 ton status
    Mar 29, 2000
    267
    Salem ,Or
    /forums/images/icons/confused.gif OK, the recent changes are 3/4ton 10 bolt front and 12 bolt rear with 4.10's, Edelbrock shocks, and dual steering stabalizers, ORD swaybar connects, poly everything. Everything has been great, driving it like this the last month. This past weekend went to the dunes, pulled a trailer 2,000lbs, and the last hour of the drive was on a rough road. Saturday had to go home for a few hours, about 80 miles, no trailer.
    It did great until I was about 4 miles from home when I started to break for a stop at about 60. Front end started to vibrate, steering wheel shake and brakes pulse. Not real bad like people talk about but not fun either. It stopped whe I did, had a few more hints of it but was mostly gone. Went back to the dunes, did some wheeling, and then towed tralier home, then GF drove to town and did it to her.
    I just jacked it up and checked all the joints, everything is tight. Bearings are tight, everything looks good. Need help here, need to be driving a few hundred miles this weekend.
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    If it only happens when you step on the brakes it is not DW. It is a warpped rotor.
  3. Ben Malinski
    Ben Malinski Guest
    What is DW? Thanks!
  4. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,259
    72
    Humboldt/Pacifica, CA
    That would be my guess too. The rotors overheated and became warped.
  5. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    The dreaded DEATH WOBBLE... /forums/images/icons/shocked.gif
  6. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Yeah, like Chevyfumes said...........Death Wobble.........do a search, you'll get more posts than you have time to read. Good info tho......... /forums/images/icons/tongue.gif
  7. Nrose07
    Mar 29, 2000
    267
    Salem ,Or
    No its not the rotors, they would pulse when cold after a warp. Mine do not. I've been current on the DW but not sure why mine? And its not DW, more WTF-Wobble. Thanks guys, Matt.
  8. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    WTF-Wobble...I like that.
    With a pulsating brake peddle I don't know what else it could be but brakes. Does it ever happen when you arn't on the brakes?
  9. rlhenry
    rlhenry Registered Member
    Mar 6, 2002
    93
    Morenci, AZ
    That's not altogether true. Hot brakes caused the rotor to warp, but the vibration you are feeling is a function of how hard you are applying the brake and what speed you are traveling. The harder you brake and the higher the speed, the more any warp in the rotor is trasferred through to the steering. Death Wobble is completely different and much worse.
  10. Nrose07
    Mar 29, 2000
    267
    Salem ,Or
    It will do it off the brakes, I think. Guess I'll have to pay more attention.
