Do I have room???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 79blzrfan, Dec 29, 2004.
  1. 79blzrfan
    79blzrfan Registered Member
    Mar 9, 2004
    21
    Michigan
    Can I run 33's on my 79 with just a 2" body lift or do I need to go with more height??
  2. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    If not, :hack: :hack: :hack: :hack:
  3. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    You'll have plenty of room.
  4. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    I have a friend with a 2in body lift and he fits 33 with no problems. He could fit 35's if he cut out some of his rust and fenders.
    Later
  5. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    I ran 33 x 12.5 R16.5 on chrome wagon wheels with no lift on the 80 K20. They would rub at the corner of the fenders if the body leaned or going over a bump. With 2" body lift you "should" be fine. Alot will depend on how sagged the springs are and what offset wheel you are going to use (the offset controls the outer "arc" of the tire while turning.
  6. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    a stock k5 will run w/ 32" tires w/o problem. can stick the 33" on and have it rub just a little. so you will be fine with the 2" body lift. :waytogo:
  7. 79blzrfan
    Mar 9, 2004
    21
    Michigan
    Thanks for the quick reply
    Scott
