Do I have the right carrier??(14FF)PICS Prob Solved
Discussion in 'The Garage' started by desertrat67, Apr 3, 2007.
  1. desertrat67
    desertrat67 Hawk Driver
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    I tried to install the ring gear on the open cattier I have and I bottomed out the bolts and still had about 3-16'-1/4" gap between the ring gear and carrier. I did not have lock wwashers installed on the bolts. The bolts were from Randy's R&P specifically for installing 5:13 gears on a standard 4.56 and lower(numerically higher) carrier(I only got the bolts and didn't notice the lockwashers on my 3.73 setup until the bottoming out of the bolts occured). Do I have the right carrier or are the lockwashers mandatory and the cause of my problem?
    Pic one is the 3.73 carrier, pic 2 is the 4.56 and lower carrier with measurements, and pic three is the 3.73 carrier again with measurments.
  2. mrdrinksalil
    mrdrinksalil 1/2 ton status
    Apr 4, 2005
    1,595
    Atlanta, Georgia
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    You are backwards. The thicker carrier is for 4.56 and up and the bolts are longer for the 4.56 carrier that is why you are bottoming out before the bolts are seated.
    You should get new bolts if you are using the thinner carrier.
    Ira
  4. desertrat67
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    that shows me having a thick carrier with 3.73 gears, just the oposite of what that post shows. WTF?!?!
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    In order to install 4.56 and numerically higher gears on a 4.10 and numerically lower carrier you need thick gears. So with that being said the 1st and 3rd pic would appear to be a 4.56-up carrier and the 2nd pic would be a 4.10-down carrier. Hope that made sense to you.
  6. sandawgk5
    Oct 28, 2003
    6,881
    I just noticed you are installing 5.13s. Did you get thick 5.13 gears or regular? That could be part of the problem. The thicker carrier is for 4.56 and up gear sets the thinner carrier is used for thick gear sets (i.e. 5.13 or 5.38).
    Ira
  7. desertrat67
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    Well, it makes sense how you say it, but not how it is. The 1st and 2nd pics have a 3.73 gearset on it. Not a 4.10, 4.56,5.13, etc. The ring gear is stamped with 41 11. that equals 3.7272727272 when you divide 41/11. Kind of aggravated here.
  8. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Even if he has thick gears he still has the wrong carrier. With a 4.56 carrier and thick gears the carrier would never fit back into the housing.
  9. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Did you buy the carrier from someone or did you remove it from a known working diff? If you bought the carrier from someone then it may have just had a wrong gear on it and someone sold it to you with incorrect info.
  10. sandawgk5
    Oct 28, 2003
    6,881
    Did you pull it out of the axle or did someone sell a 3.73 set on a 4.56 and up carrier? The break by the way is 4.10 and lower (numerically) and 4.56 and higher.
    The lower (4.10 and down) will fit on a 4.56 carrier but will not fit in the axle properly.
    Ira
  11. desertrat67
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    I got the thin gears.
  12. desertrat67
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    i was driving it with the 3.73s installed on the thick carier
  13. desertrat67
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    The other carrier came with the truck when I bought it so I could go with lower gears
  14. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    AFAIK that isn't possible. You need thick gears on a 4.10-down carrier if you wanted 4.56, 4.88 or 5.13's and if you had a 4.56-up carrier and wanted 4.10, 3.73, or even worse 3.08's you would need thin gears and i'm not aware of any "thin" gears.
  15. desertrat67
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    Problem Solved!! The previous owner said it had 3.73s in the axle. It has 4.56s. I guess I now have a 4.10 open carrier for sale and two sets of 4.56 gears. Guess i'll have to start looking for an open 4.56 carrier. :mad:
    Thank you all for your help in diagnosing my problem.
    ryan
  16. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Why not just buy 5.13 thick gears.
  17. sandawgk5
    Oct 28, 2003
    6,881
    If it had 4.56s and you have thin 5.13s then you have what you need there is no issue.
    Ira
  18. desertrat67
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    None in stock when I ordered my gears last summer, and they cost almost twice as much.
  19. desertrat67
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    Yup, time to weld a gov lock.
  20. sandawgk5
    Oct 28, 2003
    6,881
    :doah: Did not realize you took out a gov-loc.
    So ya you need a 4.56 and up open if a detroit is in the plans.
    Ira
