Do I Need a Brake Upgrade???
Discussion in 'The Garage' started by Mudbug1979, Sep 4, 2003.
  1. Mudbug1979
    Mudbug1979 1/2 ton status
    Aug 4, 2002
    439
    Monroe,North Carolina
    I recently changed the front and rear axels over to 3/4 ton running gear.( 10 bolt 8 lug/14 bolt ff rear)New brake shoes and pads front and rear with new wheel cyclinders in the rear. My problem is that the pedal feels weak now and I cannot no matter what I try make the wheels lock up and slide the tires. I have also put on a TBI to make it more offroad worthy and it has a little bit of a cam in it which causes a little less vaccum than I like. I have ordered a vaccum canister that I will be installing tonight to try to help matters. If this doesn't work what would suggest be my next option. Tire size if it matters is 36/14.5/16.5 on steel wheels with 4.10 gears. Thanks for all the info. /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/ears.gif
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Sounds like you need to bleed the brakes again. Any air in the lines will cause a loss in stopping power. I should know, I still have some air in mine.. I need to get it powerbled.
    My .02,
    John
  3. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    If it doesn't improve after the re-bleed then try this..
    Take off the MC and right behind it is a (looks like a eng valve when you take it out..I forgot what it is called) and take that to your local pick n pull and get one of the same thing out of a 3/4 ton truck ...Make sure it has the same dia shank as the one you took out but it will have a bigger face and then swap that one in put the MC back on and the brakes should be better...Worth a shot,good luck
    A friend did that on his 70 and he had good brakes now... /forums/images/graemlins/thumb.gif
  4. Mudbug1979
    Aug 4, 2002
    439
    I did a power bleed at our shop with a pneumatic brake bleeder and got all of the air out and completely flushed the system out. Still feels like there is a block of wood under the pedal when I push it though. /forums/images/graemlins/1zhelp.gif
  5. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    Then most likely you have a vacuum problem. Either the brake booster is bad or you have a leak somewhere.
    Air in the lines gives a soft pedal feel. No vacuum is a hard pedal.
    John
  6. toy4fun
    toy4fun 1/2 ton status
    Sep 10, 2002
    220
    Helper, UT.
    I had the same problem when did my 3/4 ton swap. It turns out that the back brakes were so far out of adjustment they were not even helping and a power bleed at the local shop and now have to be careful not to lock up the 36s
  7. Mudbug1979
    Aug 4, 2002
    439
    The back brakes seem to be adjusted fine. I can only move the parking brake about 4 or 5 clicks before the are extremely tight. It's driving me crazy because I have to start slowing down along way before I even get to a stop and heaven forbid someone pull out in front of me.
  8. mkinnunen
    mkinnunen Registered Member
    Aug 29, 2003
    43
    Albuquerque
    I have the same problem and am really concerned about somebody cutting me off and then slam on the brakes, I'll run them over for sure.
  9. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Sounds like you just need more vacum (or a cam with less duration or some Rhodes lifters).
    You could try and find a dual booster that will mate up as well.
