Do I need a longer e-brake cable?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85scottsdale, Feb 18, 2004.
  1. 85scottsdale
    85scottsdale 1/2 ton status
    Dec 22, 2003
    283
    Lewisville, NC
    I have a 4" suspension lift on my 85 K10 and I disconnected the ebrake which has the single cable along the driver side and then splits to go to the seperate wheels. The passenger side cable was plenty long after the lift, but my driver side one I had to run over the spring and it was kind of tight. I'm worried about it breaking or something when flexed out. Can I get a longer cable for it, or will it be ok?
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    I made a drop bracket for it, well not a bracket just a spacer. The bracket that holds it up is held to the frame w/ 2 rivits. Drill/chisel/hammer/grind/beat them out. I used a sleeve out of a spring bushing cut in half. It is the metal sleeve that goes inside of a bushing. Anyway, run a bolt through the stock bracket, through the spacers, through the frame and put a nut on. Then your cable will be long enough. In this pic you can see the bracket.
  3. 85scottsdale
    Dec 22, 2003
    283
    Lewisville, NC
    I see what you did now, I could take the sleeves out of my old stock springs.
  4. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Yeh, I cut mine in half, may be better if you either leave em full length or cut like a 1/4 off. So you use the piece that is 3/4 the length. I think the reason I cut was full length it put a kink in the cable.
  5. 85scottsdale
    Dec 22, 2003
    283
    Lewisville, NC
    I'll leave them full length and check it, and then cut it down some from there if needed.
  6. 85scottsdale
    Dec 22, 2003
    283
    Lewisville, NC
    Do you still have your stock cable routed beneath the spring like it was stock?
  7. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Sure do. Off topic, but where is lewisville at? That closer to mountains or the beach or is it in the middle?
  8. 85scottsdale
    Dec 22, 2003
    283
    Lewisville, NC
    Its about 10 mins west from winston-salem. Kind of in the middle but close to the mountains.
  9. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    o ok, BowtieRed lives in winston salem i believe.
