do I need a new ECM?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mrkay, Aug 22, 2000.
  1. mrkay
    mrkay Registered Member
    Mar 21, 2000
    44
    Plymouth, Ma.
    My 88 Blazer (fuel injection) has been idling high since I bought it 5 months ago. I can kick it down only slightly. But it is very high even then. I checked the seal around the Throttlebody carb and replaced the Idle air control motor. No change.
    The manual says that the idle is controlled by the ECM if you have fuel injection. Is there a way to test this? This is the box that contains the computer chip and sends out the diagnostic signals. Can I get one at a junk yard?
    Any one had experience with this?
    I'd appreciate any help. My drive train is taking a beating.
    <font color=blue>Rock climbing on Plymouth Rock</font color=blue>[​IMG]
    with my 88 Blazer 350/Auto/TBI[​IMG]
  2. sosamantx
    sosamantx 1/2 ton status
    Aug 14, 2000
    393
    somewhere in Texas
  3. realsquash
    realsquash 1/2 ton status
    Jul 12, 2000
    778
    SE WI
  4. mrkay
    Mar 21, 2000
    44
    Plymouth, Ma.
    I just put in a new IAC - Idle Air control motor - It has a little spring tip on it. This did'nt change anything. The one I took out was gummed up with black goop.
  5. mrkay
    Mar 21, 2000
    44
    Plymouth, Ma.
    With a new IAC in I thought it would slow the idle properly. But nothing changed at all.
  6. realsquash
    Jul 12, 2000
    778
    SE WI
    You've gotta find the IAC passage on the throttle body (the other end of the hole where the IAC mounts). The IAC does the same thing as moving the throttle plates, but only at idle. It is a "controlled" vacuum leak. Find the IAC passage and put your finger over it. If the idle speed slows down, you know you have a wiring/ECM problem (since you replaced the IAC already it prolly isn't that). The other thing is to make sure that your throttle plates are closing properly. They aren't supposed to be completely closed, but not very open. You should have an adjusting screw on the linkage on the side of the TB to adjust, but if you didn't move it, don't timker with it.
    Does the Service Engine Soon light come on at all?
    Squash
    http://www.trailrunners4x4.org/users/realsquash
  7. mrkay
    Mar 21, 2000
    44
    Plymouth, Ma.
    OK, I understand the reason for the IAC now. Since I put in a new one, the assumption is that the idle should have slowed down correctly. Since it has'nt, I'll pull it and block the hole and see if the idle slows. If it slows, do I assume that there is a mechanical problem or an ECM issue?
  8. realsquash
    Jul 12, 2000
    778
    SE WI
    No, don't remove the IAC. There is a hole, separate from the throttle bores (but inside the air cleaner's base gasket), where you will detect vacuum if you stick a finger in it. If you find the hole and there isn't any vacuum, you have either a bad IAC, bad IAC wiring, a bad ECM, or throttle blades that aren't closing for some reason, such as drebris on the linkage, mis-adjusted set screw on the throttle lever, etc.
    I would bet on the throttle sticking open a little bit.
    Squash
  9. River
    River 1/2 ton status
    May 8, 2000
    121
    Amstelveen, Netherlands
    Is it possible that you your car has a airco that is not function good. When you turn your airco on the ECM will increase the idle speed.
    An other possibility is that the axle off your TBI is leaking vacuum.
    Goodluck.
    Greetings from River,
    River `90 K5, 350, TH700R4, NP241, "33, 3.08, 10 bolt F, 10 Bolt R
