Do I need drop steering arm
Discussion in 'The Garage' started by Flybye121, Dec 8, 2005.
  1. Flybye121
    Flybye121 Newbie
    Mar 9, 2005
    Long Island, New York
    I'm installing a 3" suspension lift on my 88 K5, do I need to install a drop steering arm or can I leave it stock.
  2. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    It would definatelly help. I would.
  3. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    there are raised steering arms and dropped pitman arms. Your application needs a dropped pitman arm. You can get them from ORD I believe.
    James
  4. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    I know Skyjacker has a 2.5" one.
  5. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    you have three items you can use to correct steering on a stock setup
    drop drag link, Super lift makes a nice one but they tend to be about 4 or 6 inches of drop. too much for your3 inch lift.
    raised steering arm. goes on the axle and is around a 5 (IIRC) inch lift of the arm height. still to much for your app.
    drop steering arm. goes on the steering box and is around 2.5 or so inches of drop. perfect for your app. I think i have one but i need to verify it up against a stock arm. when i do that i will PM you and let you know. if it is a drop arm ill sell it cheap.
    Grant
  6. supernaut
    supernaut Registered Member
    May 2, 2005
    94
    Seattle, WA
    Isn't that one coming directly off the splines on the steering box the Pitman arm?
    I would love to take whatever it is called off your hands if flyebye121 doesn't get it from you.
