do i need new driveshafts??
Discussion in 'The Garage' started by XHitman396, Mar 4, 2003.
  1. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    i plan on putting a 6" lift with ORD shackles and their 2" rear springs and their 6" front lift, do i need to get new driveshafts for this? what about the same lift but with 4"?? or the 4" lift plus a 2" body lift?? how much would this cost me?? thanks..
  2. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    chances are pretty good that you will either need new shafts or need to get the ones you have modified. I would go for new shafts from high angle. they are prett reasonable, bulletproof and with the members discount even better /forums/images/graemlins/thumb.gif I know on my 72, with 4" rear lift I am pushing the limit of my rear drive shaft...
    I think the new shafts are reasonable... round $250.00 if I remember right.
    -Ryan /forums/images/graemlins/k5.gif
  3. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    I have an 87 /forums/images/graemlins/k5.gif with 6'' TC EZ-ride front springs with longer shackles and ORD flip with 2'' block in the rear. If you lower your transfer case you will be OKAY, but in reality you will eventually want to step up to a C/V rear driveshaft (I have been using the stock shafts with the lift for more than a year with no problems.) As for the front I used a 1'' driveshaft spacer from superlift and ground down the stops for the C/V. Both of the shafts were long enough, the rear just doesn't like to run at that severe of an angle and the front hit the t-case X-member until I added the spacer.
