Do I need new lift blocks with 14ff conversion?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by WARP1, Jul 20, 2001.
  1. WARP1
    WARP1 Registered Member
    Apr 8, 2000
    63
    Omaha, Nebraska
    Will I need new lift blocks with a 14FF conversion. I know I'll need new U-bolts and mounting plates. If I do, how much are lift blocks? Should I just get new 4" lift springs?
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You can use your existing blocks. But you will need new u-bolts to fit around the 14-bolt's axle tubes.
  3. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>I had 2" blocks and 2" springs and when I put my 14ff in I went to a 1" block. It was about 1" higher in the back before the swap and was about 2" higher after it so I got shorter blocks.</font color=blue>
