DO I NEED THE BRAKE BOOSTER FOR A 3/4 TON CONV.?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BLUESMAN, Dec 7, 2001.
  1. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    I'm gonna install 3/4 ton diffs in my '78.Do I need the brake booster and cylinder from the 3/4 ton truck?It's all on the donor truck,so should I just install the whole brake system?
  2. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    Yes and no.......The brake booster for a 3/4T with the 13" brake option has more assist. Will your 1/2T booster work, Yes. You may have a little more peddle effort with the half ton but it will work fine. If you have the 3/4T booster I would use it as it is an easy swap and gives you a little more boost if you ever need it.
  3. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    If you really want to make a differance, put a 1 ton master cylinder on it. Thats what i did and i couldnt believe the braking ability.
    <a target="_blank" href=http://www.geocities.com/outlaw613/K5.html>http://www.geocities.com/outlaw613/K5.html</a>
  4. 1986Blazer
    1986Blazer 1/2 ton status
    Jun 13, 2001
    511
    Key West, FL - Southernmost Point
    Does the 1 ton master cylinder mate up to the 1/2 ton booster?
    <a target="_blank" href=http://www.geocities.com/keywestk5/KeyWestK5.html>http://www.geocities.com/keywestk5/KeyWestK5.html</a>
    So I says to him, I said, "get your own monkey."
    1986 K5, 350 GM Crate, 700R4, NP208
  5. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I have 1 ton axles and I am still running the 1/2 ton master cylinder and booster. Everything works fine but I plan to upgrade it someday.
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  6. prjt_blzr
    Mar 4, 2001
    352
    COS, CO
    Are you still using vacuum assist or did you go to hydra boost?? If you are using vacuum what application is the booster intended for.
  7. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Ditto with Wayne on this - running the same stock 1/2 ton stuff on my 79 with no problems, and no pedal effort change over the 1/2 ton axles versus the D50/14BFF.
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com>www.blazzinor.rockcrawler.com</a>
  8. BurbinOR
    5,829
    Oregon
    Ditto with Wayne on this - running the same stock 1/2 ton stuff on my 79 with no problems, and no pedal effort change going from the 1/2 ton axles to the D60/14BFF.
  9. outlaw612
    Feb 11, 2001
    2,342
    Yes, the 1 ton MC will bolt right up. the brake lines with work.
  10. outlaw612
    Feb 11, 2001
    2,342
    Im still useing the stock vaccum booster.
