Do I need the sleeve/clip/o-ring for speedo gear replacement?
Discussion in 'The Garage' started by foxman, May 14, 2004.
  1. foxman
    foxman 1/2 ton status
    Oct 22, 2001
    251
    Detroit MI
    Do I need the whole kit in order to replace my speedo gears or can I just get away with the 2 gears? My np208 needs 17 tooth drive/ 40 tooth driven gears...
    Thanks.
    Jeremy
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    all you need are the gears, unless something is missing or broke.
  3. dyeager535
    26,975
    It may depend. If the gears are different enough from stock, a new sleeve *might* be necessary.
    Can't remember if it is the TH350 or TH400 (or both) but there are different sleeves based on the gear tooth count.
  4. mccomas
    mccomas 1/2 ton status
    May 30, 2003
    262
    Fayetteville, NC
    it depends on what your old housing (sleeve) had in it. a 34 to 39 tooth driven gear takes a different housing then that of a 40 to 45 tooth driven gear
