Do I need the spindle nut adapter kit to install Warn hubs?
Discussion in 'The Garage' started by paveslave, Nov 21, 2003.
  1. paveslave
    paveslave Registered Member
    Oct 11, 2003
    36
    Crestview, FL
    I have corporate 10 bolts with auto hubs, do I need the adapter kit to install Warns? The footnotes say it's needed for the 3 hole cap, I have a 5 hole cap, all the pics of Warn hubs have 6 screws (I realize on the sites the pics are a lot of times representation of the product). Are the Warn hubs for this application 5 hole? /forums/images/graemlins/confused.gif /forums/images/graemlins/k5.gif
  2. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    Not 100% sure but I believe the 3 hole reference is for Ford applications. AFAIK, you can install the new hubs without any special parts.
  3. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    no you don't need the adaptor kit. just what comes in the box with the hubs. the holes don't matter. the bolts in them just go to the inner part of your hub, which gets replaced with the new hubs. once you get the new hubs, and start taking apart your auto ones, you'll see what i'm talking about. hope this helps. /forums/images/graemlins/thumb.gif
    Rick
  4. paveslave
    Oct 11, 2003
    36
    Crestview, FL
    I've already pulled the guts out of the auto hubs. The hubs I'm getting should be internal?? The screws should hold this entire assembly in?? Still /forums/images/graemlins/confused.gif /forums/images/graemlins/k5.gif
  5. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    you should have taken 2 snap rings off when you pulled the guts out. the snap rings hold the hub inside the wheel hub. the screws hold the dial indicator to the inner guts of the lock-out.
  6. paveslave
    Oct 11, 2003
    36
    Crestview, FL
    Thanks for the info! /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
