Do I need to change the lenght of my drive shaft when I put in my 14 bolt?
Discussion in 'The Garage' started by bajaviking, Nov 26, 2004.
  1. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    As it says above, will I need to shorten/lenghten my driveshaft when I install the 14 bolt FF?
  2. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    I think it is slightly shorter than your rear 12 bolt. It is the same length to the pinion as a 10 bolt rear end. I highly doubt you will need to change the length of your driveshaft though.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    No you don't need to change your driveshaft.
  4. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Ditto.
    NO.
    U-joint will be different size.
  5. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Stock suspension?
    I had to drop the t-case to keep the rear yoke from binding.
    That was with a 465/205 slip yoke.
    Now that I swapped in a fixed yoke output and a new shaft the driveline angle is alot better though.
