Do i need to replace brake lines??
Discussion in 'The Garage' started by Tshane, Apr 8, 2003.
  1. Tshane
    Tshane 1/2 ton status
    Nov 26, 2002
    144
    Peoria, Illinois
    With a 4" lift do you have to replace brake lines??
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
  3. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Without a doubt, yes.
  4. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    Yes
    and go with some stainless steel line too you can find rubber but the breaks is not a place to start getting cheap /forums/images/graemlins/ignore.gif
  5. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    i dunno guys, i put those napa brake hoses on my truck when i put on my R\C 4" lift., dang, that thing stops better then it ever did, also some new calipers /forums/images/graemlins/wink.gif. /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  6. DwarF
    DwarF 1/2 ton status
    Mar 29, 2001
    226
    Austin, Tx
    I am running a 4" lift, and I put my truck on a forklift to see max flex, and my stock brake lines were just fine. I am about to add some additional flex, so I now need new lines, but it was fine with the 4" lift.
  7. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    not necessarily. If your front springs are stiff... or you run an anti-sway bar you may never flex enuff so that brake lines are a problem. Also, you could simply relocate the brackets that hold your brake lines. Would that be more work? sure, but you wouldnt HAVE to buy new brake lines. /forums/images/graemlins/grin.gif
    j
