Do I need to rotate my axles?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Dieselmh, Jan 10, 2002.
  1. Dieselmh
    Dieselmh 1/2 ton status
    910
    Texas
    If I lift my K5 8 inches with springs, do I need to cut, rotate, and weld my axles to get proper angles, or will shims work? I know that it could get really expensive to rotate a D60 and 14 bolt, because I don't think that it's something I would feel comfortable doing. I hate to waste all that money if it's not necessary. Has anybody done an 8 inch suspension lift here? If so, let me know what I need to look for and what to expect.
    Diesel
    Shouldn't it be called uncommon sense?
  2. ChadH82
    ChadH82 1/2 ton status
    May 9, 2001
    400
    Stillwater, Oklahoma
    The expensive part is having someone rotate the FRONT axle. I'm not sure if you would have to do that for a 8" lift or not. I'm going to have around that much and I don't plan on doing it but who knows. To correct the rear you can just use shims, move the spring hangers, or do a shackle flip.
    Chad
    '73 Blazer,383,400,Atlas II,D60/14 Bolt,traclok/detroit,39.5 Swamps <a target="_blank" href=http://members.aol.com/fileholder2meg/projblazer.html>Clicky</a>
