do i really need an H pipe?
Discussion in 'The Garage' started by shaun89, Nov 5, 2005.
  1. shaun89
    shaun89 1/2 ton status
    Aug 7, 2005
    1,942
    center of CT..ish
    my blazer orignally had a dual exhaust on it when i bought it, but it was set up for being a street queen....i lifted it and the clocking down the t case hit the exhaust so i had to rip it all down and keep the cats and mufflers, and now im making my own path for the dual....the H pipe is making this process a real pain...i wanna kill the thing, so does anyone know the pluses and minuses to taking the H pipe off and just having a dual exhaust? will it be worth going crazy over?
  2. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,922
    333
    Fort McMurray, Alberta
    You'll loose a bit of torque, and pick up that bumpy exhaust note, but it won't hurt a thing running true duals :)
    If it is easier to run them that way, by all means, can the H-pipe
  3. shaun89
    Aug 7, 2005
    1,942
    center of CT..ish
    awesome man...thanks a lot for the advice
  4. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Can also increase the in-cab resonance to the point where you will NOT want to drive at certain rpm's. That would be an extreme case, but BT,DT.
  5. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Does your rig have interior? Also, what size duals will you be running? Is your engine mostly stock or modified? Those all play into it.
    My '74 has no interior and I had to wear ear plugs while driving down the freeway due to the resonance before I put the H-pipe in. It made a HUGE difference for me for noise. If you have interior, it shouldn't be too bad. You'll lose a little bit of low end grunt, but probably not enough to make a huge difference.
  6. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    ya my blazer is a daily driver with just headers and a full interior. im a teenager so im sure the little bit louder note wont bug me too much :D thanks for the input guys :bow:
