Do I really need these?
Discussion in 'The Garage' started by Yohinan, May 19, 2006.
  1. Yohinan
    Yohinan 1/2 ton status
    May 21, 2003
    103
    San Diego
    Ok so I am putting the two inch rancho A-arm lift on. What it calls for is the following tools to get the job done. These are all Kent Moore tools.
    J 23742 Ball Joint Seperator
    J 36616 Differential Carrier Bushing Remover
    J 36202 Torsion Bar Unloading tool.
    For some reason these tools are a bi*@! to get ahold of plus the prices seem even worse than the Snap On trucks prices. What I am wondering is are these tools absolutely required to get the job done? If so does anyone know what the equivilant Snap On tool would be as I cant seem to find them in SnapOn's catalog (both online and paper copy). The snap on truck can get me the torsion bar unloading tool for like 160.00 but if I remember right cant I just back the bolt out that pushes on the hex keyed bar that the torsion bar runs through (using a floor jack also)? I think thats all I did to get old key out to stuff in the ford key. I found ball joint seperators in the Snap On catalog but there are different sizes and I am not sure which one cross references to the Kent Moore tool. Snap On guy is not sure either. Anyone know the right one I need to get? That leaves me with the differential carrier bushing remover. Snap On guy doesnt seem to have one of those either so I may be stuck buying the KM tool if there is no other way to get the bushing out. Any other tools I can use to get that or is the remover required? TIA for all the help. John
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Harbor Freight is your friend.....................
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    ....or what about renting them at Auto Zone?
  4. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    IIRC autozone has all these tools and yes you need them.
  5. Yohinan
    May 21, 2003
    103
    San Diego
    Well I guess I will take the plunge and buy the KM tools. I refuse to buy the majority of stuff that harbor freight sells. Additionally after 2 tool rentals from Auto Zone I wont rent from them anymore either.
    I can get one part for sure from Snap On (torsion bar unloading tool). The ball joint seperator if I can find out what size it is I can get that from the SnapOn guy also. Anyone know what size the ball joint seperator is from KM? Not sure what the equivelant SnapOn would be. They have a 5/8", 13/16", 1", and 1 1/4".
    For sure though looks like I gotta get the KM Diff Carrier Bushing Remover.
    Anyone know a store that sells to the public that carries KM tools and keeps them in stock? I am in San Diego if that makes any difference.
    Thank you guys so much for all the help. It's greatly appreciated. John
  6. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    The only tool you really need the the unloader for the torsion bars. I installed a DC 6.5" system on a chevy and the TB were the worst part.
    The other tools you could do without
  7. JDNobodi
    JDNobodi 1/2 ton status Premium Member
    Oct 9, 2002
    3,008
    197
    Santa Maria, CA
    I've never used a ball joint seperator. I've just beat the knuckle by the taper and the taper pops loose. A seperator would be nice if everthing is painted or powder coated and don't want to ruin the finish.
  8. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I just put a Trailmaster 6" kit on my '96 and never used any unloader. I put the jack under the lower control arm, removed the frame bolts for the upper control arm, then lowered the jack until there was no tension on the adjusting bolts. I put it back together this way also with no problems.
    And what is a "rancho A-arm lift"?
  9. Yohinan
    May 21, 2003
    103
    San Diego
    The rancho a-arm lift changes out your upper a arm for their model which will give you a 2" lift. If you have no lift already then your just getting 2" but if you have a 6" already then your at 8". That about sums it up.
  10. divorced
    Jul 20, 2004
    5,115
    If all you are doing is replacing the upper arm, you don't even have to unload the torsion bars. You shouldn't need any special tools, unless you can't get the ball joint loose... then you will need the Ball Joint Seperator (pickle fork). This almost seems too easy... maybe I am missing something... like why they say you need the Differential Carrier Bushing Remover?
