Do it yourself bed liner ?
Discussion in 'The Garage' started by steedalx, Feb 1, 2004.
  1. steedalx
    steedalx 1/2 ton status
    Dec 19, 2003
    142
    Chattanooga, TN
    I am planning on planning on coating the interior of my Jimmy with some type of roll on bed liner. Just wondering who has done this and how you rated the product. So far I have been reading up on Durabak and Herculiner...has anybody used one of these or something else?
  2. PeteH
    PeteH 1/2 ton status
    Mar 26, 2003
    498
    San Jose
    everyone asks bout liners! /forums/images/graemlins/angryfire.gif but its okay i did too /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/rotfl.gif
    hurculiner is awsome! just finished my tub, doors, and rails, but now i still have to do the side parts of my truck. dont know much bout durabak but......hurculiner worked for me, i finish a them few days ago and then it just rained in my truck(full convertable, no top right now)and it was fine/forums/images/graemlins/grin.gif
  3. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    I did the duplicolor bed liner in mine, I didnt have any problems putting it in and and seems fairly tough. But after it dried and I fired up the truck and the noise was horrible. It sounded like yelling into the grand canyon, terrible echo. Thie beign my daily driver I spent 30$ on some carpt and padding and put it on top of the liner and now I keep thinking my truck stalled because its so quiet.
  4. LlanoK5
    LlanoK5 1/2 ton status
    May 26, 2002
    202
    Llano, Tx
    I used Herculiner, it is a great product. Maker sure that you take the time to prep it correctly. My only complaint is the noise, but then again now I can hear every little noise that my truck makes. It's been rained in a have a dozen times, only thing to get damaged was the stereo (wind blew rain through the half cab into the dash).
    All in all I would say it's a great product.
  5. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    I did the Duplicolor also. I think I'll be sticking with the Herculiner for my next project. Duplicolor was cheaper but it's basicly thick paint and it flaked off quite a bit in some spots. Even with 3 coats of the stuff it would scratch off if I was dragging my spare tire or my hi-lift across the bed. It is cheap to touch up though and it comes in a spray can to get into all the tight places...
  6. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Herc is pretty good....well, as long as you keep it off yer hootus...
  7. trogdor4x4
    trogdor4x4 Registered Member
    Dec 15, 2003
    37
    Spring, TX
    It is a great produce for the Price, I picked it up at o'Reily's for about $100. With 3 coats I covered the whole floor, fender wells, and lower part of door below plastic panels.
  8. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I herculined the Jeep and had the K5 professionally done with Line-X. Based on what I've seen so far, I'd get it done right if you can stand the $$. The Herc is now starting to get thin in spots and has some chipped off places. Maybe I wasn't as careful as I should have been, but you have to consider that too. /forums/images/graemlins/grin.gif It's tough to get everything perfect with the little roller. I was by no means sloppy. We spent all day and tried to do everything by the book.
    Now I need to decide whether to touch up with more herc or coat the entire thing with Line-X or Rhino.
    FWIW, I think Line-X is tougher than Rhino, but Rhino is thicker and softer so it might be better if you're worried about noise.
  9. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    i tried the duplicolor spray in bedliner on the floor of my k10, it is rubbed off where my right heel rests just below the gas and where my left heel rests between the clutch and brake pedals.. i also used it on the doors just below the panel on the uncovered part and tried it on the door panel itself, it flaked off the panel, but holds great on the door itself, and i would use it again, but only on my roof and doors...
  10. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    I used Heculiner in my rig. If I were to do it again, I would pay Rhino Linings to do for me cause their liners are thicker and alittle more plyable like rubber.
    Bill
  11. 83_chevy_blazer
    83_chevy_blazer Registered Member
    Nov 18, 2003
    20
    i just got my balzer done with vortex spray on liner its kind of like line x but it isnt as rough.
  12. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    I used Dupli-color roll on in the tub of my 70 Jimmy. Carefully prepped and put on 4 coats. Doesnt hold up any better than paint and its faded badly in the AZ sun in one year. If you can afford it have it professionly done, if ya want to do it yourself try another product. Good luck! /forums/images/graemlins/thumb.gif
  13. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    /forums/images/graemlins/histerical.gif
  14. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    Thats what i used, herculiner. and as stated above......
    I accidently knealed in some, with long pants on. had a HARD time getting those pants off after it started setting up!! My knee was "tainted" black for 3 weeks!! couldn't get it off with any chemical I found!!
    /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif
  15. Scrubby
    Scrubby 1/2 ton status
    Dec 1, 2001
    114
    Boise, ID
    How is that vortex? I have been looking at it for my '72. It is definately cheaper than line-x or rhino. I just don't know how the quality is.
  16. atlantak-5er
    atlantak-5er 1/2 ton status
    Aug 20, 2003
    225
    Atlanta, GA
    I used Herculiner. For what I paid, I am happy w/ the results. It does come off in areas where it is thin or if you haul lumber or steel in your bed. But, the good thing is, you can just re-apply it for cheap in the needed spots.
  17. 89Jimmy
    89Jimmy 1/2 ton status
    192
    Northern N.Y. east end of Lake Ontario
    I used duraback on the outside of my K5 and it's holding up fine. Got some fading after 2 years. Recoated and was good. A little expensive.
    John
  18. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    John
    got any pics?
  19. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    I went all the way to metal
    /forums/images/graemlins/peace.gif
    after
    Mine has held up good, faded some but it's ok /forums/images/graemlins/waytogo.gif
