Do it yourself traction tread on nerf bars?
Discussion in 'The Garage' started by dremu, Sep 19, 2006.
  1. dremu
    Feb 27, 2000
    15,963
    454
    East of San Francisco
    Wanna put some no-slip grip stuff on my nerfs ... fear not, it's not my 'wheeler, it's for my DD-ish K5 :D
    Anyway, I was thinking I could do some like spray-on adhesive and then some sand ... any other ideas as to a cheap & easy way to add some anti-slip to slick metal?
    -- A
  2. czd3my
    czd3my Registered Member
    Sep 9, 2006
    20
    OKC, OK
    Around here the local hardware stores sell adhesive backed non-slip "tape". Usually made by 3M; I have used it on nerfs before with good results. It's pretty resonable $!
  3. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    That's what I put on my slider's topsides. :waytogo: :waytogo:
  4. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    they also make a paint with sand in it... prolly cost you more at first then tape but you can coat and recoat when it wears out.
  5. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    I've heard of people mixing up sand into house paint and putting it on stairs, wonder if that would work. :dunno:
  6. 79k20350
    Nov 22, 2004
    7,757
    Ct
    They make a sand for paint to, couldnt use house paint though (latex) would have to use an enamel (something like rustoleoum in a can)
  7. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    pfsh, what, like you've never seen an entire truck painted with house paint and brushes before? Not that I know anyone like that....:o
  8. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    There is a sand for mixing into paint, my dad owns a true value and sells it by the pint, its more like beach sand than regular playground sand. its a bit finer. But ya its ment for mixing into floor paint for nonskid. What i did when i was painting mine was sprayed the slider then sprinkled sand all over it, then painted over it 3-4 coats to lock it in, Most of its still there 4 years later. Worked pretty good. and doesn't peal off the way some of the tapes can.
  9. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    try durabak bedliner
  10. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Ive used "grip tape" get it from OSH, Home Depot, Lowes, Ace, etc.
  11. WRENCH-HEAD
    WRENCH-HEAD 1/2 ton status
    Dec 25, 2005
    327
    Littleton, CO
    I masked of the area and used herculiner. Durable and you sure as hell won't slip off of it.
  12. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Yep non skid tape for boat decks and the like it was the first thing I put on mine, 6' of 2" will do both sides, it's lasted for ever too and is still in great shape.
  13. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    There's two types of non-skid tape. That with a sand-like finish and one that's more like the bedliner stuff. IME the bedliner-like stuff works better when wet.
    If you opt for the anti-skid paint additive & can't get it from your local paint store try a boat place. I know West Marine carries the additive as I bought some to put in the paint that never got applied to the plywood in my roof rack. :doah: :doah:
  14. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    ATV shops have the rough non-skid in sheet form also.
