DO SF 14 BOLTS EXIST IN 88 3500 GMC TRUCKS???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Brians 60s, Sep 7, 2001.
  1. Brians 60s
    Brians 60s 1/2 ton status
    Jun 12, 2000
    1,115
    Bend, Oregon
    I found a 1988 gmc 3500 truck that was lightly rolled. A guy I know is selling it for $500. I went to go look at it earlier today and to my amazment, it had a sf 14 bolt underneath it. Not only that, but I always thought 3500's and k30's did not change body styles till 92. I saw the registration to confirm the year and 3500 status. Did someone swap this thing in, or am i losing it.
    IT'S A 1 TON THING.... IF I HAVE TO EXPLAIN IT, YOU WOULDN'T UNDERSTAND!!!
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    No clue - you'd almost have to decode the VIN. Sounds to me like a K2500 "salvage title special" - a set of 3500 doors, and a DMV inspector who just wrote what was on the badging.
    1 tequila 2 tequila 3 tequila Floor
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    The 3500 regular cab trucks did go to the new body in '88, only the crew cab trucks kept the old body through '91. I believe the single rear wheel 3500 trucks did get the sf 14 begining in '88.
    '85 K5 : Run it til it breaks, then fix it and go again!
  4. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    The single cab, single rear wheel '88 3500s had Dana 70s in them, actually 70-3s they were called. Only the 2500s should have had the SF14b, and even then, the HEAVY 2500s with the 454 option would have a FF 70-3. I don't know why they didn't use FF 14Bs, but they didn't.
    ken
  5. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    Where can I find more info on the FF 70-3 axles. Do these axles have the pinion like a 14FF? Do they have 14 bolts on the cover. I have one out of a 88 1 ton crew cab that looks like a 14FF but it has alot more cooling fins on the pumpkin than I have seen before on 14FF. Could this be one of those FF 70-3's? Thanks for your help in advance, and if you or anyone knows where to find some pictures of these axles (FF 70-3) that would be great.
    See Ya,
    Keith
    [​IMG] <font color=green>Born to Drive My K5</font color=green> [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/californiak5>CaliforniaK5's Pictures</a>
  6. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Dana 70s use the same 10 bolt cover as the Dana 60s.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  7. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I know the 14B SF's are a 6 lug design... are any of the others a 6 lug tupe design? I would relly love a bit stronger rear for towing then the 12B, but really hate to change wheels and tires for a 14B ff.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  8. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Some 14 SF's are 8 lug too - my buddy's got an 83 K20 with a SF rear.
  9. elkboy
    elkboy 1/2 ton status
    Aug 18, 2000
    293
    Hillsboro Oregon
    My dad had a 89 3500 extra cab 4x4 SRW 8800 GVW. It had a 14 FF in it ( I know I changed several seals in it). 8800 GVW was the lowest GVW available for a late 80's (88 and later) 3500. I remember when he bought it he had to go 3500 for the FF in the rear to tow his 5th wheel and the main diff from the 2500 was the FF 14 bolt rear. The 2500 that year maxed out at ~8200 GVW and had a SF 14 bolt. The 6 bolt 14 bolt SF came in the under 7200 GVW 2500 trucks. If the truck is a 3500 and has a SF 14 bolt in it it's been changed.
    <font color=red> Elkboy </font color=red> 82 K5 fuel injected H.O.305, TH350/205, 14bolt/10bolt and 39.5 TSL's.
  10. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    Brian,
    When I was stationed in Norfolk we had an 88 3500 with the IFS front and SF14 bolt rear at work. The truck was single rear wheel longbed single cab. Maybe it was just a military contract or something, but it was there.
    Russ
  11. elkboy
    Aug 18, 2000
    293
    Hillsboro Oregon
    The standard cab 3500 must have been light enough to get by with the SF 14bolt. I had an 85 K20 rated at 8600 GVW with a SF 14bolt. I've never seen seen a 3500 with a SF, but I belive they must have made some.
  12. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    I had a 88 heavy 3/4 ton 4x4 suburban and it had a sf 14 and it had a gvw of 8600. Don't know if this helps much
  13. californiak5
    Oct 25, 2000
    820
    Thanks for the info Pete. I thought they were like the 60's but was not sure.
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Mikey, my SF 14 bolt is 8 lug ('52 K20).
    Tim
  15. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    I've been searching for one that is decently priced, but have yet to even find one. New or old... would probably end up getting some superior or Moser axle shafts in 6 lug and want to move up to 4.56's. Just wondering what everyone has seen them selling for around them
    -Mikey
