Do the 14ff rear disc conversions have the same stopping power?
Discussion in 'The Garage' started by bigblock454, Apr 27, 2003.
  1. bigblock454
    bigblock454 Clack Clack Clack Premium Member
    Jun 18, 2002
    546
    16
    Terre Haute IN
    I was thinking of installing rear discs on my 14ff. This is for my diesel burb that does lots of towing, do the discs have the same or better stopping power?
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Definately better!
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Oh, yeah. Much Better. I've been thinking about putting them on my 1 ton dually.
  4. wadinator
    wadinator 1/2 ton status
    Dec 18, 2001
    233
    NW Iowa
    Actually, I've heard otherwise! The main benefit of the rear discs is that they're cheaper to repair/replace and you drop about 150lbs from the rearend. But stopping power from the disc isn't better because the friction surface of the drum is all at the maximum radius from the center of the wheel (13" or something like that), but the disc/pad friction surface is spread from like 8-12" (however tall the pad is).
    I proly didn't explain this well enough to make sense, but I know what I mean to say. Wish I could draw ya a picture.
    In any case, I've head arguments from brake experts that say the rear disc conversion doesn't do a lot for increased braking.
  5. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Less brake fade is the is the main benefit that discs give you. Ask a tow-truck driver.
    They also self-clean better. Drums can plug up if your truck sees a lot of mud.
  6. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Its closer to 75 pounds that you lose. The surface area is less but it is more efficient. Clamping works better than pushing against a surface. I also noticed a huge difference when I made my conversion.
  7. wadinator
    Dec 18, 2001
    233
    NW Iowa
    Yup, I totally agree with both of those statements. I guess I forgot to mention those. If you're a hard-core wheeler, especially into mudding, then a disc swap is definitely a good thing because they do clean themselves so much better than the drums. /forums/images/graemlins/crazy.gif
