do the make a smaller diameter distributor?
Discussion in 'The Garage' started by reddog64, Nov 15, 2002.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    I want a "not so wide" distributor...
    Does some one make one? One that isnot so big and round but small and round?
    Part number? /forums/images/graemlins/1zhelp.gif
  2. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    MSD Ignition Systems! Seperate coil & Dist.!
    Bill
  3. ratlover
    ratlover 1/2 ton status
    Aug 5, 2002
    215
    Peorial IL
    There is also a guy on the net that makes small bodied(points style) distributor conversions.
    http://www.davessmallbodyheis.com/
    Give him a call, very cool dude to work with and he will set it up for your application.
  4. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    I prefer MSD products but the Mallory Unilite distributor is pretty small.
  5. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I agree, I have a MSD distributor w/ the external coil and I like it.
    So, it uses a points-type cap and is a good deal smaller.
    -- Mike
  6. reddog64
    Nov 9, 2000
    3,325
    I'm happy with the stock HEI but I noticed with the old sbc 400 in there (assume new 350 will be the same) that the distributor appeares to be resting on the firewall or extremely close... ??? /forums/images/graemlins/eek.gif
  7. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    I use a Mallory magnetic breakerless dist. I would not use the Uni-light in offroad vehicles. The module is to sensitive to dirt and moisture. The unit I use is basiclly a HEI. I had a HEI GM dist. in my '72 and if I flexed hard the firewall would break the ign. cap! Thats why I use the Mallory now. MSD also makes a "small" dia. HEI unit, however they are abit more expencive than the Mallory. /forums/images/graemlins/thumb.gif
