Do these work?
Discussion in 'The Garage' started by Hobbs, Apr 11, 2006.
  1. Hobbs
    Hobbs Registered Member
    Feb 28, 2006
    28
    Alabama
    Do these exhaust pipe expanders work? Will these let me take stock 3" pipe and prepare it for a slip fit system?
    Thanks,
    Hobbs
  2. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    I think it depends on how much pressure you can apply to them before they break.
    I have one that works up to a 2.5" hole. I tried to expand a 2.25" but it does not expand the pipe after it reaches that limit. There is still more thread room, but it just doesnt have the power to expand the metal beyond its original form. It does, however, work pretty well at taking the crimps out that get left by the exhaust clamps.
    For your application, I think you would need to get pipe that is pre-expanded for a slip system. Though I may just not have the right tooling for it.
    Hope that helps
  3. detailer03
    detailer03 1/2 ton status
    Sep 23, 2003
    108
    Arizona
    All they are really good for is to expand a pipe a very little, or get a kink out if the pipe had a clamp on it.
    If you want to expand the pipe, go to a shop that does custom work and ask them.
    Also, keep in mind, you can only expand to the pipes limits then is just splits.
    I used to run a shop that did custom work, I found out on my stuff the hard way.:eek1:
  4. Hobbs
    Feb 28, 2006
    28
    Alabama
    Thanks all. Thats what I thoughts.
    Hobbs
  5. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    I own a couple different sizes of these...
    As the others said, it is minimal, but enough to expand 1 of 2 pipes the same size to fit over the first, remove crimps, etc... We used to use it on marine hose believe it or not...
