do ujoints click when bad??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by little79k5, Oct 24, 2002.
  1. little79k5
    little79k5 1/2 ton status
    Mar 27, 2002
    230
    panama city, fl
    do/can ujoints make a clicking sound when not greased properly?thanks
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    yup....
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Yes and it happened to me last week, that was too late for me, it was the sound of the caps breaking the ridge that holds the c clip, and they are out. /forums/images/graemlins/frown.gif
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Yes, they will click. But by the time they are making a sound like that it's too late to simply grease them. A click out of u-joint is "u-joint-ese" for "replace me before I explode and drop your driveshaft!!!"
    The best way I can describe the sound is to say it sounds like marbles dropping onto glass- kind of a ticking/clicking deal. Once you've heard it, you'll never forget it..... /forums/images/graemlins/wink.gif
  5. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    My front shaft sounds like that, been doing it for a year now... (crossing fingers!) I just hope it holds out until I get a doubler installed so I can get measurements and do it right!
  6. Can Can
    15,552
    136
    Hmmmmmmmmm....... /forums/images/graemlins/ooo.gif
    Everytime one of my u-joints has got to the clicking stage, it'seither been in bad shape or on the verge of failing. Is there a chance that the clicking is coming from somewhere else up front? I know that a cracked flywheel can sound similar......
  7. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    A cracked exhaust manifold will make a distinct clicking sound when accelerating too.
  8. rogerwilco71
    rogerwilco71 1/2 ton status
    Sep 22, 2002
    179
    Central-Cal
    My u-joints use to just absolutely EXPLODE! POW! KABOOM!(kinda like a scene outof batman)
    I my early days of shimming and angles, the top joint and yoke would be hot.
    Might as well change it for a better piece of mind. Only 10-16 bucks...course on my rigs, clicking could've been any thing /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/smile.gif
  9. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Cracked flyweel, cracked flexplate (or bolts), U-jointss... they can all make clicking noises - Exhaust leaks usually sound more like a lifter.
  10. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    yea, that happened to me when mine went bad, it didnt explodhowever
    one cap cracked in 1/2, lost the clip, and all of the bearing inside, when i took it off, it made me wonder how it was possible that the ujoint stayed on! /forums/images/graemlins/blush.gif /forums/images/graemlins/eek.gif
  11. nofeartruckin00
    nofeartruckin00 1/2 ton status
    Oct 5, 2001
    798
    Germantown, Wisconsin
    Is it possible for a u-joint to "click" even if all 4 caps are seated properly and all 4 c-clips are in place? (busted needle bearings possible???)
  12. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Yes, if there is little grease inside and it is about ready to go............had that happen first lifted truck, for two days couldn't figure out what that clicking sound was until the u-joint let go, SLAMMING the driveshaft up into the tranny tunner............. /forums/images/graemlins/shocked.gif
  13. nofeartruckin00
    Oct 5, 2001
    798
    Thanks, time for another $25 conversion joint /forums/images/graemlins/rolleyes.gif
