Do you grease the slip yolk on the np208?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Pookster, Jun 25, 2003.
  1. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Well, do you? or dont you? Im thinking yes, cause it needs some kinda lube. Wacha all think?
  2. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    yes go ahead and do it it may keep it from klunking longer , but i never did .
  3. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    I never have, and doubt its necessary since it will be bathed in ATF all the time anyway as long as the level in the case is as it should be.
  4. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Do you mean grease the splines or the out side of the slipyoke?
  5. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    i put a little bearing grease on the slip part of mine. it helps keep it from binding up.
  6. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    i did when i redid my slip yoke seal, not a bad idea at all. i think it did help some. /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I like to grease the pan just a bit before I slip the yolks in... /forums/images/graemlins/wink.gif
    As for those slip yokes, I think GM has a special grease that you can use on the splines that will help prevent binding. /forums/images/graemlins/cool.gif Twizted is a GM tech, drop him a PM and he might be able to get ya a part number. /forums/images/graemlins/thumb.gif
  8. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    I used regular bearing grease on mine and the clunk went away......
  9. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    When I replaced the output seal on my 208, I filled the recess between the inner & outer lips of the seal with grease, and I put a light coating of grease on the outside of the slipyoke shaft. I also put a little ATF on the splines inside the shaft (used a small paintbrush) to keep things smooth. Worked great, no leaks nearly 2 years later.
