do you have to remove the carrier to install a lockrite in a front. d44?
Discussion in 'The Garage' started by **DONOTDELETE**, Apr 2, 2002.
  1. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Yup!.... I have had to every time I've done it. Can't get the cross pin out without removing the ring gear.
    Marv
  2. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    I think it depends on the gear ratio, with my 4.56s (old front end), I had to remove it.
    Pete
  3. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    I dont think th e gear ratio is going to matter. I had 3.08's when I got mine and put it in the front and stll had to remove the carrier to put it in. Just be careful of shims and put it back the same way you put it in. I had never done it before and it was not nearly as hard as I thought it was going to be.
    Depdog
  4. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    I have one as well and always have to remove the ring gear.
  5. Storm24m
    Storm24m 1/2 ton status
    Mar 12, 2002
    148
    Knob Noster, MO
    I think with the lock-rights, it depends on the thickness of the ring gear. Thin ring gears can be done without removal, thick gears require removal. Check out http://www.offroadexchange.com/daklocker.htm for some pretty good details on installing a lock-right on a Dakota.
  6. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    pretty much what everyone said already...
    did one with 3.73's and had to remove the ring gear from the carrier.
    ric
